Tire spinning
Old Mar 28, 2003 | 07:53 AM
raj20's Avatar
Default Tire spinning
Just wondering how easy it is to spin the tires on the S2000. I don't have one yet, but I've driven RWD cars before. Its fun to throw the tail out sometimes, but can the S2000 do it with such low torque?
Thanks!
-Raj
Old Mar 28, 2003 | 08:05 AM
Draff1's Avatar
I'm wondering the same thing. Have on 2300 mi and I've been kind during break - in. I've heard the 5.4 0 - 60 claim involves a 7k RPM clutch drop. Not sure it's worth the abuse. Any comments?
Old Mar 28, 2003 | 09:34 AM
raj20's Avatar
I've also heard that about the 0-60 time. One magazine said "Don't expect to achieve a 5.4sec 0-60 often, unless you want to be on a first name basis with your parts dealer."
-Raj
Old Mar 28, 2003 | 10:43 AM
Ron Jeremy's Avatar
Spinning the tires is not a problem as long as you keep the RPM's high enough.
Old Mar 28, 2003 | 10:46 AM
RyanITV's Avatar
Depends on how you want to do it - straight line, you'd need to sidestep the clutch at a high enough RPM, thereby running the risk of doing some damage to the drivetrain or causing premature clutch wear. Donuts are another story - turn the wheel while rolling in first and blip the throttle. The ass end slides right out and will keep chewing up the tires as long as you want. The only downside to spinning around like mad is that you're eating up tires.
Ryan
Old Mar 28, 2003 | 11:30 AM
Draff1's Avatar
Can somebody detail some of the changes Honda incorporated into the car for 2002? I heard a beefier rearend and stouter clutch. Is this true?
Old Mar 28, 2003 | 11:41 AM
billyjoho's Avatar
It's pretty easy to spin the tires. You just have to keep the RPMs up but be ready to spend money on new tires.
Old Mar 28, 2003 | 12:12 PM
iceple's Avatar
Spining tire?Buy your S give it to me and i will show u how to u do.
Low torgue?Test drive one..and u tell me.
S2000 Blk on blk
91 Miata FM2
Old Mar 28, 2003 | 12:38 PM
2Ting's Avatar
Is that why you should never take turns when youre RPMS are high (ie Vtec Range)
Old Mar 28, 2003 | 12:50 PM
Bret's Avatar
More specifically, you should be careful when your RPM's are high and you downshift during a turn. If you upset the balance of the car too much, around you will go.
