Tires after a caynon run? (pic inside)
i can see some marks on the side side as below:
only on the right front tire, i didn't run off the road, no huge huge under steer into anything, i was running 33 psi at all 4 corners.
is this bad?
is this bad?
I think it would be almost impossible to cause the S-02 to roll over on the side that much from cornering forces, especially with proper inflation. The sidewalls on these tires are so stiff...
edit: Forgot to add, be thankful that you didn't rub the rim!
I also think it's just curb rash.. If you would have rolled the tire thru a turn, you would be able to see the marks all around the tire. Since your tires were rotating at a very high rate, it would have to mark the whole tire..
I would respectfully suggest you take it to a track or autocross. Unless you're out for a Sunday stroll, leave the canyons to BMW deathwishers:
http://216.118.86.224/m3forum/showthread.p...?threadid=16109
