Tires don't chirp.
Old Oct 13, 2007 | 08:17 AM
Jamie_Murray's Avatar
Default Tires don't chirp.
Stupid question but I'm curious.
When shifting into 2nd gear while driving spiritedly my tire do not chirp like every other S2000.
Instead the rear breaks traction for about a half second to a second. I can feel the back end going back and forth.
My tires are the stock S-02 with great tread (green on the tire card honda has given me)
This is during very dry weather by the way. Do the S-02's just not chirp?
Old Oct 13, 2007 | 08:19 AM
WashabiS2K's Avatar
check your alignment and your tire pressures. if the rear end swings while you are shifting hard, it could be that the tires DO, in fact, chirp, but the alignment is so horribly off that you would actually start sliding.. thats exactly what was wrong with my car when i first bought it, any 9k shifts resulted in the rear end swinging dangerously outward. had my alignment done to proper specs and the sliding stopped.
Old Oct 13, 2007 | 08:21 AM
rocrfella's Avatar
It means you don't have enough POWA!!! Put a CAI or supercharger or turbo in it and you'll hear it.
Old Oct 13, 2007 | 08:26 AM
I assumed it was because I had more power if my tires are spinning longer.
My end doesn't swing violently out, justt about a foot.
Old Oct 13, 2007 | 08:34 AM
Enthralled's Avatar
things to check
tire pressure
nails
alignment
I had a nail in one of my rears before and caused the exact same thing.
Old Oct 13, 2007 | 08:43 AM
Just checked the tires over and there is no nail.
What should the correct pressure be?
I think I'm going to wait untill I get ap2 rims for an alignment.
Old Oct 13, 2007 | 08:48 AM
Soul Coughing's Avatar
i have 290ft/lbs of torque and don't usually break the tires loose in a 1-2 shift. I also have a 9lb flywheel and 6 puck, and the car feels to break loose or at least dig down for a sec, if that makes any sense...
Old Oct 13, 2007 | 09:18 AM
TB's Avatar
TB
This is not the reason.
As others have said, bad alignment or tires.
Old Oct 13, 2007 | 09:35 AM
Alrighty, thank you very much everyone.
