Too Much Rev-Match
Old Jul 3, 2008 | 07:43 PM
ROTFLMAO's Avatar
Default Too Much Rev-Match
What happens when you try to match the revs and overshoot the RPMs say by 500-1000RPMs more than the right amount? Is it just as bad as not rev-matching at all or is it worse?
Old Jul 3, 2008 | 07:52 PM
JstnRyan's Avatar
Going too far over is just as bad as going too far under (maybe slightly less bad as it would seem easier to slow the engine, than speed the entire mass of the car.
The goal of rev matching is to get as close as possible.
Old Jul 3, 2008 | 08:41 PM
niahuynh's Avatar
how do your know the speed when to rev-match? ap1 and ap2 are different right? Sorry I'm a newbee.
Old Jul 3, 2008 | 09:08 PM
SoMe0nE2tAlK2's Avatar
for me it just took about a month to get used to the revs of the car at different gears & speeds. After a while it just becomes natural.
Old Jul 3, 2008 | 10:10 PM
J'sS2K's Avatar
If you over-rev in a rev-match, it just going to jerk a little. No big deal. But if you don't, then the clutch will take up the slack and that is bad!
Old Jul 3, 2008 | 11:20 PM
SIIK2NR's Avatar
Better to overshoot and learn to drop it a little than to rev and miss your timing and have the clutch take the brunt. If your shifting below the optimum rpm.....then your not rev-matching at all. Your just reving your engine and still shifting normally.
Old Jul 4, 2008 | 04:47 AM
smurf2k's Avatar
no.
Old Jul 4, 2008 | 08:19 AM
EVAN&MONICA's Avatar
Just keep practicing dont worry about it some people take longer to learn than others. Monica is still learning, the clutch may need replaced after she gets it down better
Old Jul 4, 2008 | 09:45 AM
Ks320's Avatar
And i feel that the car jolts more if I undershoot. Where as overshooting doesn't as much. But heck, that probably doesn't make much sense hehehehhehe
I don't know. I find that overshooting is more comffy than undershooting
Either way, there will be more wear on the clutch than a perfect match hehehehehe
Old Jul 4, 2008 | 11:51 AM
ROTFLMAO's Avatar
That is exactly the feeling I get. Thanks guys, I will keep on practicing. I usually overshoot the rev-match when I am at the lower RPMs at lower speeds.
