top is getting stuck
I've noticed that my top is getting stuck when I try to put it down. It folds back but then stops before it goes below the level of the wind deflector. I then bring it back up half way and back down again - this usually does the trick.
Has anyone else had this problem? I've tried looking but can't see where the top is getting hung up.
Thanks,
Dave
Thanks,
Dave
There's a support bar that's supposed to fold back - when I've seen tops not go down all the way, it's because that bar folds towards the front. It's because the elastic straps loose their elasticity and can't pull the bar into its proper position.
Check the latches and see if it is getting lose. That's what happened to me a couple of months ago, Driver side latches came lose and was holding the top before it folds, it actually scratched the top right behind the latches. Nasty... it eventually broke off and I had to take back to the dealer... got latch and top replaced under warrenty though.
