Top Speed for Each Gear
Old Dec 11, 2007 | 04:07 PM
J'sS2K's Avatar
Default Top Speed for Each Gear
Does anyone know where I can find the top speed for each gear on our car? Today, I downshifted to 2nd at 57mph, and I was just wondering if that is within the 2nd gear range for that speed. Was I over-revved the car? Thanks.
Video added: >>>Click here<<< (Exceeded bandwidth)
After reading the comments, I don't it was that bad any more , but I want to show you guys the video anyway.
This is when I installed the Megan Resonated Test Pipe and took it out for a spin. I've never revved that high ever since I got it, so I thought this would be the good time to do so Enough said... Enjoy
Jason
Old Dec 11, 2007 | 04:26 PM
modMonkey's Avatar
Try this tread for reference:
https://www.s2ki.com/forums/index.ph...ic=356730&st=0
For an AP2, you are close.
Old Dec 11, 2007 | 05:05 PM
s2kforlife's Avatar
you should be fine if that is the exact number.
Old Dec 11, 2007 | 06:02 PM
Greg W's Avatar
I've seen 58 in 2nd in my AP2 before the rev limiter kicked in, so you should be OK.
Old Dec 11, 2007 | 06:12 PM
CKit's Avatar
Some guys with the AP1 ECU in the AP2 spin their F22C that high and are fine. Usually 11k rpm is when things start to go very bad.
Old Dec 11, 2007 | 06:14 PM
trapper's Avatar
Look here .....
http://www.turnzero.com/technical_resource...gear_calculator
Old Dec 11, 2007 | 10:32 PM
JLEEzAP2's Avatar
57-58 is around 8200 in 2nd gear for an ap2
Old Dec 12, 2007 | 01:28 AM
AlX Boi's Avatar
I've accidentally hit 70mph in 2nd while misshifting before. I recently got my retainers checked and everything is A okay. My mechanic followed Billman's posts and pics of what overrevved retainers look like. Mine looked normal. You should still get it checked though.
https://www.s2ki.com/forums/index.ph...&f=22&t=313647
https://www.s2ki.com/forums/index.ph...&f=22&t=442653
Old Dec 12, 2007 | 06:26 AM
J'sS2K's Avatar
[QUOTE=AlX Boi,Dec 12 2007, 02:28 AM] I've accidentally hit 70mph in 2nd while misshifting before.
Old Dec 13, 2007 | 07:58 PM
Ks320's Avatar
That was a close one!
