Top speed run
Old Mar 5, 2006 | 08:48 AM
jaws's Avatar
Default Top speed run
I apologize if this is a repost, but I can't believe this speed. 280 kmh (~175 mph) is fast. Notice the tach bouncing into the rev limiter.
Video
Old Mar 5, 2006 | 09:05 AM
Wisconsin S2k's Avatar
that's the infamous turbo dave video. however, he was NOT FI. he was n/a. he had a couple bolt ons, but the main reason he was able to reach the top speed (and go beyond the drag limited 155+/-) was because he was going down a slight hill at the end.
this shows the top speed of an ap1 that has enough power to get it there, is about 175mph. in stock form, though, it's only going to get between 150-160 or so, drag limited.
Old Mar 5, 2006 | 09:10 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
THAT was fast.!!!
Old Mar 5, 2006 | 07:41 PM
twohoos's Avatar
Yes to everything except the 175mph -- the car's gearing does not allow anything over 165 (that's redline in 6th). The rest is speedo error.
Old Mar 5, 2006 | 08:11 PM
MugenRioS2k1's Avatar
with somthing like a yellow box it would be possible to get the speedo to read higher than the actual speed.
Old Mar 5, 2006 | 08:28 PM
Johnny Sack's Avatar
all factory speedo's are inacurate over about 110 or so.
Old Mar 5, 2006 | 10:55 PM
trivium's Avatar
Banned
wow. Just wow.
Old Mar 6, 2006 | 01:32 AM
Riceboi's Avatar
Dang, when he passes that first truck near the end if you look in the rearview mirror you can see the headlights of the truck fading FAST!!! lol That's pretty nuts...
Old Mar 6, 2006 | 04:16 AM
ruexp67's Avatar
Unless my GPS was off by the same ammount, my Speedo was pretty much spot-on to 138. Not sure after that, it was as high as it got on that run.
Closed course of course.
Old Mar 6, 2006 | 06:12 AM
I disagree. friend of mine has done 168mph in his FI'd S2000 verified by GPS. the speedo was reading 171mph. only 3mph off. he was just a tad below redline. there is tire flex that you are not accounting for. a simple math calculator will not be able to pinpoint the exact mph.
