trunk spring noise
Old Sep 3, 2001 | 02:29 AM
verone24's Avatar
Default trunk spring noise
Hello,
Have any of you guys heard the trunk spring move after you have locked the trunk? Maybe its just me. I thought that it could be the spare tire cover catching the spring....maybe i am wrong.
V
Old Sep 3, 2001 | 03:53 AM
Ronald's Avatar
Yes, I think it's a standard feauture. I had it with both my 1st as well as my 2nd S2000. But it doesn't bother me enough do look into it.
Old Sep 3, 2001 | 05:57 AM
John MI blk/blk '01's Avatar
Could the noise be the license plate frame?
Old Sep 3, 2001 | 06:41 AM
Cyclops's Avatar
I have it too, the rear spring at a particular point actually changes position from above to below the front spring. The sound is the flexing/unflexing of the back spring moving past the front.
I tried lubricating the rubber with a bit of armor all to see if that helped. It did not, but the springs seem to pass eachother a bit easier.
I moved the front spring forward, that did work, but only temporarily.
I am going to try to make a plastic or rubber spacer to move the front spring off of the back spring just a hair....or maybe I will just live with it
Old Sep 3, 2001 | 08:48 AM
Utah S2K's Avatar
Normal......you've found one of the few design defects on the car. Be intetreting to see if it's still there for MY'02.
lewiS2K
Nov 14, 2008 04:49 PM
slightly2ned
Jul 29, 2008 12:58 AM
estribo714
Nov 6, 2006 10:49 PM
estribo714
Socal Swap Meet
Nov 6, 2006 10:48 PM
douglasmaurer
Aug 8, 2003 05:32 PM
