trying to explain to a guy at work :-(
Old Jan 8, 2003 | 12:58 PM
KMCC's Avatar
Originally posted by rickycrx
If you are leaving your car in 5th gear while just 'cruising' on the highway (I.E. not passing quickly), then you are just wasting gas and spinning your engine unnecessarily.
I've got to agree with rickycrx on this one.
In the physical world that I live in, higher revs means more wear on engine parts and is not offset in the long run by the nifty sounds that emanate from the exhaust.
But then, I'm one of those who intends to keep his S2000 for many years in as nearly mint condition as is possible.
Old Jan 8, 2003 | 01:12 PM
speed_bump's Avatar
You might want to get your oil banjo bolts done Euro style if you run at high rev on the highway for long periods of time.
Old Jan 8, 2003 | 01:17 PM
DarioManfretti's Avatar
[QUOTE]Originally posted by KMCC
[B]
[b][COLOR=red]I've got to agree with rickycrx on this one.
Old Jan 8, 2003 | 01:40 PM
Gernby's Avatar
Former Sponsor
Originally posted by b0mbrman
When I was learning to drive stick, the guy who was teaching me told me a good rule of thumb is to shift around 1800 rpm's and bring it up to 3k if I need the power...
If you are driving a 4 cylinder at 1800 RPMs, you are lugging the engine and putting excessive wear on the engine and transmission. Check the owners manual for recommended cruising RPMs.
The S2000 engine has maybe 30 HP at 2K RPMs. I am only able to guess on this, since my last dyno chart started at 2500 RPMs, where it had 50 HP.
Old Jan 8, 2003 | 01:59 PM
Roku_F20C's Avatar
[B]
Old Jan 8, 2003 | 02:30 PM
rjm161's Avatar
[QUOTE]Originally posted by DarioManfretti
[B]
What KMCC said.
Old Jan 8, 2003 | 03:01 PM
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by rjm161
[B]
My del Sol is sitting at home with a burnt valve just and over 101k on the clock.
Old Jan 8, 2003 | 05:45 PM
yells2k's Avatar
I would tell your friend that with his mentality he should be driving a diesel engine that way he would have gobs of torque and never have to rev past 4000 rpm's. Reving high is all relative to what you are used to. We rev til 9000 because we can
Old Jan 8, 2003 | 05:52 PM
Destiny2002's Avatar
6000 RPM in a 4 cylinder is the same as 4000 RPM in a 6 cylinder or 3000 RPM in an 8 cylinder. so what? If the engine is made for 9000 RPM you better not drive it around at 2000 RPM for long...
Old Jan 8, 2003 | 08:31 PM
Barry in Wyoming's Avatar
[QUOTE]Originally posted by sj2000
[B]I'm trying to explain to this guy (a 93 Integra owner)
