Update on clutches
Old Nov 18, 2001 | 02:56 PM
unregistered's Avatar
Default Update on clutches
It's now time for my second replacement clutch and I'm looking for advice on which one to get. I do some auto-X and as many Time-trials as I can. The first replacement was the stock "upgrade" but I can now feel it slip when I shift into 2nd 'energetically'.
All responses shall be much appreciated.
Thanks,
Pierre
Old Nov 18, 2001 | 03:47 PM
cdelena's Avatar
I wound up with a stage 3 Star clutch which is pretty amazing.. it does not slip even when you expect it would. The Star people do clutches for a number of race teams including some Type-R's running the Speedvision series.
There are several threads discussing my install and the fact that Bulletproof has decided to carry the line. Here is one with pics.
https://www.s2ki.com/forums/showthread.php?...ght=star+clutch
Old Nov 18, 2001 | 06:38 PM
DSF_S2k's Avatar
Cdelena has an interesting setup.
I went with the ACT Heavy Duty Clutch plate, ACT street disk and TODA flywheel. The setup is excellent, absolutely no slip what so ever. However, you can no longer clutch dump or have 'high RPM' launches... it places too much of a shock onto the drive train. I met Cdelena at TWS and we all compared clutch 'feeling'. His setup is very close to stock feeling (as much as the peddle feel goes) if I remember right. The ACT setup is quite a bit heaver, which I prefer.
Dale
Old Nov 20, 2001 | 02:10 PM
cthree's Avatar
Administrator
[QUOTE]Originally posted by DSF_S2k
[B]Cdelena has an interesting setup.
Old Nov 20, 2001 | 02:14 PM
cdelena's Avatar
Originally posted by cthree
Correct me if I'm wrong but can you not slip your new clutch now to launch vs dumping it?
Not sure about Dale's clutch, but on mine any hard start will spin the wheels, not the clutch. I have never done high rpm launches but I would guess you would only get wheel spin on my car even with sloppy clutch work.
Old Nov 20, 2001 | 02:39 PM
mingster's Avatar
i'd recommend a set of Spoon clutch cover/disk/flywheel combo.
Old Nov 21, 2001 | 05:04 AM
jguerdat's Avatar
[QUOTE]Originally posted by cdelena
[B]I wound up with a stage 3 Star clutch which is pretty amazing.. it does not slip even when you expect it would. The Star people do clutches for a number of race teams including some Type-R's running the Speedvision series.
Old Nov 21, 2001 | 05:33 AM
simon2000's Avatar
2 replacement clutch.. I'd like to be in the car when you drive .. yikes.!!!
Old Nov 22, 2001 | 10:16 PM
cthree's Avatar
Administrator
Correct me if I'm wrong but isn't the Spoon disk really just an OE Honda one?
Old Nov 22, 2001 | 10:41 PM
mingster's Avatar
no, it's supposed to have adopted a different, more up-to-date material used by spoon.
