Update, past year's experiences with the Turbo/Built S2K
Old Jun 7, 2003 | 08:52 AM
  #21
ChrisD's Avatar
Yep, could be that too.
Old Jun 7, 2003 | 03:35 PM
  #22
S2K1's Avatar
Excellent information and good luck to you in the future!
Old Jun 7, 2003 | 06:40 PM
  #23
damcgee's Avatar
Excellent write up Chris, your verbosity helps us live vicariously!
Old Jun 7, 2003 | 07:33 PM
  #24
sHaObEn (=.=)'s Avatar
Old Jun 9, 2003 | 03:03 PM
  #25
Steve@Evolution's Avatar
AEM FPR should be 1:1 ratio regulator meaning every pound of boost you make you gain 1 psi of fuel pressure on top of the static fuel pressure. Say if you are idling with 45 psi of fuel pressure and you end up making 15 pound of boost, your end fuel pressure should be 45 + 15 = 60psi of fuel pressure. However, I have a SX fuel pressure regulator and it is also 1:1. I set my idle pressure at 45 psi and runs 16 pound of boost. I checked my greddy fuel pressure warning gauge and it reads around 70 psi of pressure by the time I ran 16 pound of boost. That means on top of what suppose to be a 45+ 16 = 61 psi of fuel pressure, I gain an extra 9 psi more. You can call AEM and they will tell you the same thing that 1:1 ratio is pretty common on all aftermarket fuel pressure regulator.
Old Jun 9, 2003 | 03:28 PM
  #26
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by Hybrid
[B]AEM FPR should be 1:1 ratio regulator meaning every pound of boost you make you gain 1 psi of fuel pressure on top of the static fuel pressure.
Old Jun 9, 2003 | 07:12 PM
  #27
Yes, but I prefer to set my static fuel pressure by not pulling off the vacuam hose. It's just preference. I'm just saying the increased fuel pressure after boost is normal but it must be consistant run after run.
Old Jun 9, 2003 | 07:49 PM
  #28
BlueS2000Boy's Avatar
[QUOTE]Originally posted by ChrisD
[B]
I've already broken one ring and pinion, so I went with the Comptech differential upgrade and a Kaaz differential, although technically, I haven't addressed the situation with the ring and pinion. It's a time bomb. At some point I'd like to cryo treat the ring and pinion (this is probably priority number one).
Old Jun 9, 2003 | 08:43 PM
  #29
Pappy's Avatar
He didn't put 285's on the stock wheels. He has SSR GT1's. I believe he is running a 9.5 in the rear....
Nick
Old Jun 9, 2003 | 09:58 PM
  #30
s2knikko's Avatar
nice write up.... puts new light on that sc/turbo decision... but them hp numbers a definatelly moving....
