Upgrading Alternator?
Old Dec 14, 2000 | 06:51 AM
Z3toS2K's Avatar
[QUOTE]Originally posted by Pinky:
[B] [QUOTE]Originally posted by Z3toS2K:
[b]If you are running a high drain system such as a heavy duty stereo set up with big amps and sub, you will easily overpower the altenator in th S2000. The Optima batteries and 1 Farad Capacitors are a small fix to a system that spikes above the alt's capability on occasions.
Old Dec 14, 2000 | 08:49 AM
Pinky's Avatar
For all those watching and not posting. You can figure that our car can easily handle a pretty big amp!
Speaking from max fuses for the amp our car could probably handle a 75amp fuse total for the amps in the car with a upgraded batterie and 1-2 farads of capacity and not worry. If you end up running big subs like 2 12's then that puts a bigger strain on the car so it would be maxing out the car with a 75 amp fuse.
If you go over 75 amps for a max fuse then be ready to swap for a bigger alternator! People can probably get away with a 30 amp fuse for separates and a 40-45 for a sub amp.
Just remember that the sub amps will be the ones drawing the most power it dosent take a lot of energy to move a set of separates!
RonnieG
May 1, 2013 03:00 PM
Neuman04
Nov 19, 2009 11:28 AM
Grimnebulin
15
Oct 30, 2007 10:32 PM
REVZ TO9
Jun 1, 2006 02:57 AM
ruexp67
Apr 21, 2003 06:56 PM
