VAFC install diagram
Old Feb 18, 2006 | 07:39 PM
darkfx's Avatar
Default VAFC install diagram
got a vafc, dont have a harness.. is there a diagram to show which wires to splice anywhere? thanks
Old Feb 18, 2006 | 09:51 PM
jakub2000's Avatar
search the web for frog harnesses and do us all a favour.
Old Feb 19, 2006 | 02:38 AM
S2KPUDDYDAD's Avatar
I have the paper work for mien, call me
Old Feb 19, 2006 | 05:42 AM
spider2k's Avatar
Active Streak: 30 Days
try the apex'i web site. you can download a PDF of the destructions. the only wire they dont have is the VTM listed.
connector C
pin 10 BLU/BLK (VTM)
Old Feb 19, 2006 | 06:57 AM
darkfx's Avatar
the only diagram i saw was fo the 01 civic EX ECU
Old Feb 19, 2006 | 08:41 AM
j_c_a's Avatar
Here you go:
https://www.s2ki.com/forums/index.php?showt...0&#entry6829413
Just ignore the components you're not using. If you need a hand feel free to PM me (or call I'm on the FL contact list). I've also got the Helm's manual w/ the ECU pinouts if that helps.
Honestly though, it is worth it to get a wiring harness and do the solders outside of the car. Much easier that way.
Old Feb 19, 2006 | 12:24 PM
darkfx's Avatar
Hey jca is that diagram the same for vafc v1??
Old Feb 19, 2006 | 12:33 PM
j_c_a's Avatar
Mmm, no there are a couple of differences. I don't remember off the top of my head what they are. Do you have the vafc wiring info? b/c i can post or pm you the ecu pinouts.
Old Feb 19, 2006 | 12:37 PM
SilverKnight's Avatar
whyt not just buy a plug and play harness? no soldering needed, just plug and play
Old Feb 19, 2006 | 12:44 PM
j_c_a's Avatar
That's certainly the easiest (and cleanest way). With the harness i have (which was a vafc1 harness i had to modify btw) I still had to solder in the vafc wires, but the harness was clearly labelled and it was pretty easy to do.
