valentine one install questions
hello, i did a search but only came up with a custom mounting in the secret compartment....anyways do you guys with them put them anywhere else than on the dash.
is the secret compartment the place for them? or is custom mounts the only way to go?
thanks alot!!!
thanks alot!!!
I mount the main unit on the windshield to the right of the rear view mirror. I intentionally mounted it there so I can easily remove it upon parking or to use with my motorcycles. Plus, I feel it gets good vision fore and aft. I also run the concealed display, which I have mounted on the steering column.
Originally Posted by CrazyCracker82' date='Feb 21 2005, 06:10 AM
did you guys conceal the wires yourselves, or did you get a pro? if so how much was that? thanks
http://www.s2000.org/mods/radar/
I installed mine last week, it only takes about 10 minutes. All you need to do is replace the male spade connector with a female on the hot lead of the barrel shaped module. Then you connect the hot lead to the third accessory lead in the fuse box. It's easier to do than it is to describe. Do a search for "valentine" in the electronics forum.
Originally Posted by jackhoff' date='Feb 21 2005, 07:30 PM
i installed mine into the windscreen, and have the remote display infront of my gauges. i can take a pic tomorrow if you want.
