vibration after lowering.
I lowered my s2000 after fitting my new 18" wheels (8" front 9"rear) and now the car vibrates when under load. The front dropped 35mm and rear 40mm. Wheel alignment was done and the back had 3 degrees camber. Can anyone suggest why the vibration is occuring and a possible solution to fix it.
Your CV's are bad. They were probably already ruined, but when you lower the car, it makes it more obvious. Replace the inner CVs. OR, wait a couple months and see what Raxles comes up with. I sent them my old axles so they can prototype an improved setup that will be stronger and hold up better on lowered S2Ks.
I'm 100% sure. There is a thread in Under the Hood dealing with this exact issue. The CV's get pitted on the inside and cause a vibration that is only present under acceleration because only the side of the cv that is pushed against to accelerate gets the pitting. If something was out of balance, you'd feel it all the time, not just under accel.
The reason he started to notice it after lowering the car is that lowering creates a greater angle on the cv joints, so the rollers on the inside do more side to side traveling and rub back and forth against the pitted areas as they do so. The problem is with the inner cv because that joint allows for a push/pull motion (which is exagerated on a lowered car). The outer joint doesn't allow for push/pull, so that joint isn't a problem. I don't think lowering causes this problem in any way... but it certainly will make it noticable on a car where it may not have been noticable at stock height (as was the case with my car).
