vtec all the time
Old Jul 19, 2005 | 08:00 PM
Ks320's Avatar
http://auto.howstuffworks.com/camshaft2.htm
Just found this ... this explains everything that you are looking for (you can click on the "Switch to performance cam" button within the image to see what everyone's talking about. Enjoy! (Also click on next page as they had an excerpt on VTEC)
Old Jul 19, 2005 | 08:10 PM
jwa4378's Avatar
There is a scavaging effect when the valves open and close. Opening them sooner/later with more/less duration CAN effect the amount of air going into a cylinder at the same RPM.
Could you explain this a bit more? Even if the exhaust and intake are open longer, the same amount of air will be in the cylinder regardless of how long they are open, when they close.....pressures will equalize. Just because you have more air flowing through the intake / exhaust valves should not mean that there is more air in the cylinder when they close and combustion takes place. The flow of air should not increase the pressure of the air in the sealed chamber. Some un-burned air will most likely escape during the prolonged overlap. I see how it might help by getting the exhaust fumes out faster, but not by bringing air in.
Please clarify this so I know in the future.
John
Old Jul 19, 2005 | 08:28 PM
tizbad2k's Avatar
its not really the amount of air but the also the better mixture of air and fuel, hotter gasses have higher velocity which create a suction effect pulling in the fresh charge, also the since the fresh charge is cooler it is denser.
if you want to learn i reccomend a set of books by Carroll Smith , (tune to win, engineer to win, drive to win, prepare to win, and some other which slip my mind right now)
Old Jul 20, 2005 | 06:16 AM
jwa4378's Avatar
Thanks...I will look into it.
John
s2k_9000rpm
Dec 20, 2005 04:42 PM
GDM S2K
Dec 14, 2005 10:45 AM
dyhppy
Jul 20, 2005 01:08 AM
dyhppy
Jul 19, 2005 08:04 PM
Sky15
Jul 18, 2002 12:07 PM
