warm engine?
Old Mar 19, 2005 | 06:30 AM
  #21
Sownman's Avatar
I wait for 2 or 3 bars to pull away. I don't hit vtec for at least 15 minutes. You don't want to be pushing an engine when the oil is still cool and thick.
My last car was a Vette. It gave a seperate water and oil temp reading. The oil temp reading lags WAY behind the water temp. After 10 minutes of running the water temp would be pushing 180 degrees, but the oil was still barely over 100 degrees. The new Lotus Elise actually has a rev limiter that prevents getting into the second cam until the oil is hot enough. Elise owners report this to take as long as 15 minutes.
Steve
Old Mar 19, 2005 | 07:27 AM
  #22
HoshNasi's Avatar
no point in a prolonged idle once the engine has reached idle revs, and oil has circulated its go time. Keep in mind if you leave the car to warm up a while the diff and tranny are still way below the temps they need to be. Warming up the tranny properly is usually my biggest goal.
Old Mar 19, 2005 | 09:06 AM
  #23
JAXrsx's Avatar
Originally Posted by Shinigami,Mar 19 2005, 06:36 AM
I've heard more bad then good about pre-warming up a car.
Gently driving off seems to be the best, not only for the wallet, but it also makes it possible to deliver oil to all the engine components much quicker due to movement (otherwise resulting in dry rubbing).
After it purrs for about 30 seconds or soI roll out and take it easy till I hit 3 bars. I am more concerned about oil getting distributed thoroughly than the block cracking from temp. stress. Maybe if I lived somewhere where the car sat in sub-freezing temps, but here in FL it is not an issue.
Craig
Old Mar 19, 2005 | 09:21 AM
  #24
xviper's Avatar
Originally Posted by bitz,Mar 19 2005, 01:23 AM
It is not good for your engine to drive withouth warm up. If you drive without warming up,
that may cause a engine block to crack, especially aluminum block like ours. However, it is unlikely
to happen to modern cars though. When metals get hot, they expand. When cold
metals is forced for high temp that creates some force and cause metals to crack. Actually when
there is only one bar I believe S2K engine won't rev up to redline. It rev limits around 7K rpm.
Anyways its not like you have to but, should warm-up your engine.
(I'm not even going to explain the reason for this smilie. I think most people will understand why.)
Old Mar 19, 2005 | 09:28 AM
  #25
b0mbrman's Avatar
Old Mar 19, 2005 | 10:04 AM
  #26
PrimoAP1's Avatar
Allowing the car to sit and idle is bad for your spark plugs over time. This may not be as much of a concern for the OE platinums but the car runs very rich during warm up and sitting at idle several mornings over a period of time will increase the wear.
I wait for the air pump to turn off (approx 30 seconds) and then keep the revs under 4k until I have reached 3 bars. I also slow my shifts down and use more control while the tranny is warming.
Old Mar 19, 2005 | 10:26 AM
  #27
axis_of_evil's Avatar
I'm not a mechanical engineer but it is my sense that warming the car before 'loading' the engine would reduce wear because most parts would be [ nominally ] at their steady-state temperature, and thus have expanded to their normal configuration. Warming it up WHILE loading, even if you're gentle, would defeat the idea here. FWIW, I always warmed up my Accord and used Mobil 1 every 3K and got 336K before selling it to some college kid.
Old Mar 19, 2005 | 11:08 AM
  #28
bitz's Avatar
Probably most people at here knew it but amazingly there are people that don't know what it means
to warm-up engine. There is many drivers that looks like they're car enthusiast but right after
they turn on the engine they blast off from parking lot revving engine like crazy. I understand its
obvious for drivers like you and me or most of people out here, but also there is people actually
don't know about these. I just wrote my previous post for those people.
Old Mar 19, 2005 | 11:10 AM
  #29
honda606's Avatar
Then how about possibly listening to the majority in this thread?
Start the car, turn on the radio, buckle your seatbelt and DRIVE. I too keep it under 3-4k until three bars show up and don't VTEC until at least ten minutes after the third bar shows up on the 00-03 temp gauge. The car is designed to warm up on the go. Idling does nothing beneficial for your car or engine.
Old Mar 19, 2005 | 01:25 PM
  #30
HydnHood's Avatar
