WEAR BARS
Old Feb 23, 2001 | 06:11 AM
lvs2k's Avatar
Does anyone have any photos of their tires with the wear bars showing? I've got nearly 15K miles on my tires and haven't seen anything yet except thinning tread. Please post if you have any.
Old Feb 23, 2001 | 06:22 AM
Unicron's Avatar
These are the set I bought from Kman. Tread almost gone...need more...
Old Feb 23, 2001 | 01:14 PM
lvs2k's Avatar
Sorry, I still don't see any "wear bars".
Old Feb 23, 2001 | 04:59 PM
josh3io's Avatar
there are little rubber bars that are in the tread grooves that run sideways across the tire ( from sidewall to sidewall). when your tires are low, the bars will be even with the tread pattern. until then they're recessed from the tread inside the grooves. i'd take a pic of mine but my camera is still offline.
Old Feb 24, 2001 | 02:35 PM
Utah S2K's Avatar
Josh3iO is incorrect. Most tires have a perpendicular wear bar pattern. Not the Potenza S02. The Potenza wear bar is groove by groove, with the bar being perpendicular to the groove not the tire. The bar is also offset from groove to groove (meaning a single bar does not cross all grooves of the tire, even when warn down). If your looking for a traditional "wear bar" there is none. Look at the individual grooves.........
ramblin_wreck08
Mar 18, 2014 03:48 PM
David1
Aug 24, 2004 06:41 PM
BlueS2000Boy
Aug 23, 2002 12:18 PM
Goldtrom
Nov 3, 2001 01:43 PM
mistersleepy
May 7, 2001 01:58 PM
