What do to when the engraved voodoo shift knob won't align?? HELP pls~~
Old Feb 28, 2004 | 02:06 PM
lalaspanda's Avatar
Default What do to when the engraved voodoo shift knob won't align?? HELP pls~~
The engraving on my voodoo shift knob is just slightly off the center when the shift knob is screwed all the way down. what should i do??
Old Feb 28, 2004 | 02:11 PM
1Fast99Si's Avatar
Lock-tite(not sure if thats how they spell it)
Old Feb 28, 2004 | 02:12 PM
ReedZ's Avatar
Former Sponsor
We suggest using a bit of BLUE loctite to slightly align your shift knob. You shouldn't have any further issues after you let it harden. Every shift stalk is slightly different.
Regards
Old Feb 28, 2004 | 07:11 PM
bigpurp's Avatar
Available at Home Depot, or any hardware store?
Old Feb 28, 2004 | 07:28 PM
jarod's Avatar
[QUOTE]Originally posted by bigpurp
Old Feb 28, 2004 | 07:58 PM
lalaspanda's Avatar
thanks for the help, but i wonder how does it work. it that some kinda glue that stick the shift knob permanantly? my knob is just slightly off the center when screwed all the way down and tightened with all the power i have. Seems there's no room to screwed the knob further down to get engraving aligned, even if i use that glue stuff. any suggestion?? thank you guys....
Old Feb 28, 2004 | 08:34 PM
Spankee's Avatar
You can insert a small washers in the shift knob until theres enough thickness to let it tighten on straight. Might take you a couple times but better than loctite.
Old Feb 28, 2004 | 08:44 PM
Chitah831's Avatar
Autozone has it too. that is where I got mine. I don't have the engravings, but the knob still came loose quite often from everyday driving. The BLUE loctite works great! And if needed to take it off, a sharp twist will do the trick
Old Feb 28, 2004 | 08:58 PM
jarod's Avatar
[QUOTE]Originally posted by lalaspanda
Old Feb 29, 2004 | 05:53 AM
dlq04's Avatar
There's is no risk in using loctite. It comes in a very small tube and only a small amount is needed to coat any threads. It comes out of the tube looking like blue water. It's intended to hold nuts and bolts together when vibration might otherwise cause them to undo. It is not intended to never come apart. As was said, the knob can be removed with slightly more hand torque than one would use without loctite on it. The idea of the nut below the knob is traditionally the way shift knobs are held in place; however, with the voodoo knob it's intended to go down the shaft as far as possible. As I recall you run out of threads when it's seated properly - thus there really no room for a lock nut.
