what king of engine oil should i use?
Old May 29, 2002 | 05:07 PM
xviper's Avatar
Originally posted by Bass
if i got to mobil 1 can i prolong the oil changes to say 15k (maybe the filter every 5 with an extra quart)
Bass
Did that once on another car. At 15,000 kilometers, I could scrape the SLUDGE out from under the the valve cover with a tablespoon. But, maybe you'd like to find out the hard way like I did.
Old May 29, 2002 | 05:40 PM
DarioManfretti's Avatar
Originally posted by Tugz_S2K
Theres nothing wrong with using a 5W30. Performs and has characteristics that are the same as 10W30...except 5W30's benifit is in cold starting.
BTW I have 3700kms and am using Valvoline 10W30. Im going to switch to Mobil 1 10W30 at 8000kms.
From what I understand, Honda once said to use 5W-30, but changed it to 10W-30. An owner may have warranty issues if they don't use the proper weight.
Old May 29, 2002 | 05:44 PM
StwoK's Avatar
Originally posted by LIL RAJA
sorry, this is sort of an idiotic question. but i did not get my owner's manual yet and it's on order. So please help me answer this question.
thanks!
LIL Raja
You didn't say how many miles you have on your car. Some people have suggested synthetic motor oil. If you have less then 7,500 miles you should only use regular oil, not synthetic. Honda states for normal temperatures 10w-30 should be used. If you check a bottle of Honda motor oil at your dealership, you'll see it is made by Mobil. It's probably Mobil's Drive Clean motor oil.
Old May 29, 2002 | 08:42 PM
Russ's Avatar
5W-30 is recommended for cold weather climates and using it will NOT void one's warranty. Please...for those who believe this idioms are true, may I point you to the Magnussen-Moss Warranty Act. It makes for a great read, especially for those who modify their automobiles as I and others do. FWIW, Royal Purple 5W-30 is my oil of choice and the best I have ever used...even better than RedLine. I do a LOT of short trips so the normal 7,500 break-in point is being reduced to 6K and at that point, all fluids will receive a Royal Purple cocktail, including the tranny oil.
RoBD305
Jun 21, 2003 11:52 AM
Randman
Jan 17, 2003 08:21 PM
TCS2K
Feb 28, 2002 07:14 PM
enzyme
Aug 17, 2001 11:36 PM
shingles
Apr 4, 2001 02:26 PM
