what oil to use?
Old Sep 24, 2003 | 03:19 PM
cdel's Avatar
Default what oil to use?
Hello everyone,
My S2000 is coming up for its oil change, and I was wondering what would be the best oil to use?
My dealer uses Castrol GTX 10W40.
Any suggestions will be greatly appreciated.
Cdel
Old Sep 24, 2003 | 04:13 PM
robb's Avatar
Castrol GTX 10W30.
Old Sep 25, 2003 | 07:39 PM
dee's Avatar
dee
Bought the S in January '03. Currently has 4200 miles. Daily commutes to work approximately 9 miles one way. Should I change the oil now?
Old Sep 25, 2003 | 07:45 PM
3ngin33r1's Avatar
My suggestion, smack your dealers service manager with the Honda S2000 manual for using the wrong oil and specifically request that they follow the instructions for your car if they are going to do the work.
Or, buy your own 10W-30 and filter and either have them use it or change it yourself.
Old Sep 25, 2003 | 07:55 PM
3ngin33r1's Avatar
I think with that short of a drive back and forth you fall under the extreme condition maintenance schedule which is as follows:
3,750 mi/6,000 km
7,500 mi/12,000 km
11,250 mi/18,000 km
15,000 mi/24,000 km/1 yr
18,750 mi/30,000 km
22,500 mi/36,000 km
26,250 mi/42,000 km
30,000 mi/48,000 km/2 yrs
33,750 mi/54,000 km
37,500 mi/60,000 km
41,250 mi/66,000 km
3 years
45,000 mi/72,000 km/3 yrs
48,750 mi/78,000 km
52,500 mi/84,000 km
56,250 mi/90,000 km
60,000 mi/96,000 km/4 yrs
63,750 mi/102,000 km
67,500 mi/108,000 km
71,250 mi/114,000 km
75,00 mi/120,000 km/5 yrs
78,750 mi/126,000 km
82,500 mi/132,000 km
86,250 mi/138,000 km
6 years
90,000 mi/144,000 km/6 yrs
93,750 mi/150,000 km
97,500 mi/156,000 km
101,250 mi/162,000 km
105,000 mi/168,000 km/7 yrs
108,750 mi/174,000 km
112,500 mi/180,000 km
116,250 mi/186,000 km
120,000 mi/192,000 km/8 yrs
9 years
120,000 mi/192,000 km/10 yrs
Old Sep 25, 2003 | 08:00 PM
paivag's Avatar
Try to keep that break-in oil until 7500. I got my S in January and have about 5200 miles. I will be changing it soon most likely before I put it away for the winter.
Old Sep 25, 2003 | 08:14 PM
RazorV3's Avatar
change at 3750 miles or 6 months, whichever comes first. thats why i did and my oil came out very thick and black. oil loses its effectiveness of protecting the engine as time goes by...
btw i use castrol gtx 10w30.
Old Sep 25, 2003 | 08:21 PM
3ngin33r1's Avatar
I was mistaken, the extreme condition was for 5 miles or less commute, unless of course you are in stop and go traffic. Here is a complete maintenance schedule for both conditions:
Maintenance Schedule for Extreme Conditions.
This schedule is to be followed if you drive in one or more of these conditions most of the time:
Trips of less than 5 miles (less than 10 in freezing weather)
Extremely hot weather (over 90 degrees F)
Extensive idling or stop-and-go driving
Trailer towing, driving with a car-top carrier, or driving in the mountains
Muddy, dusty, or de-iced roads
3,750 mi/6,000 km
Replace engine oil and filter.
7,500 mi/12,000 km
Inspect front and rear brakes.
Check tire inflation and condition.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
11,250 mi/18,000 km
Replace air cleaner element.
Check parking brake adjustment.
Replace rear differential fluid.
Lubricate all hinges, locks, and latches with multi-purpose grease.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
#Inspect exhaust system.
#Inspect fuel lines and connections.
Check all lights.
Inspect the underbody.
# = See information on maintenance and emissions warranty, last column, page 151 of your owner's manual.
18,750 mi/30,000 km
22,500 mi/36,000 km
26,250 mi/42,000 km
Check all lights.
Inspect drive belt.
Replace dust and pollen filter*.
* = See dust and pollen filter on page 187 of your owner's manual for replacement information under special driving conditions.
33,750 mi/54,000 km
37,500 mi/60,000 km
41,250 mi/66,000 km
3 years
Replace brake fluid (independent of mileage).
Check all lights.
48,750 mi/78,000 km
52,500 mi/84,000 km
56,250 mi/90,000 km
Check all lights.
Inspect drive belt.
Replace transmission fluid.
Check all lights.
6 years
Check all lights.
Inspect drive belt.
Replace spark plugs.
Inspect valve clearance.
Check idle speed.
Check all lights.
Check all lights.
Inspect drive belt.
9 years
Replace engine coolant, then replace every 60,000 mi/96,000 km/5 yrs.
Maintenance Schedule for normal conditions:
7,500 mi/12,000 km
Replace engine oil.
Replace engine oil.
Replace engine oil filter.
Check all fluid levels, condition of fluids and check for leaks.
22,500 mi/36,000 km
Replace engine oil.
Replace engine oil.
Replace dust and pollen filter.
Inspect drive belt.
37,500 mi/60,000 km
Replace engine oil.
3 years
Replace engine oil.
52,500 mi/84,000 km
Replace engine oil.
Replace engine oil.
Inspect drive belt.
Replace engine oil.
75,000 mi/120,000 km/5 yrs
Replace engine oil.
Replace engine oil.
6 years
Replace engine oil.
Inspect drive belt.
Replace engine oil.
Check idle speed.
Replace engine oil.
Replace engine oil.
Replace engine oil.
Inspect drive belt.
9 years
Old Sep 25, 2003 | 08:28 PM
Nerdboy's Avatar
Either someone likes to type or has a little too much time on their hands.
Old Sep 25, 2003 | 08:31 PM
3ngin33r1's Avatar
Nope, I already had it in a file, I just C&P'd
stickercutting
Nov 25, 2024 11:11 AM
msculptor
Feb 25, 2011 02:41 PM
disenador
Oct 16, 2003 10:31 AM
x46359
Oct 10, 2003 06:38 AM
SECRET AP1
Aug 8, 2002 07:35 PM
