what tire pressure do you use
Old Jan 7, 2002 | 06:32 PM
REV2NINE's Avatar
Default what tire pressure do you use
how much tire pressure should i have on my car???
Old Jan 7, 2002 | 06:40 PM
bayarea408's Avatar
32psi all around
Old Jan 7, 2002 | 06:42 PM
Utah S2K's Avatar
Old Jan 7, 2002 | 11:19 PM
MarkS2K's Avatar
33 psi all around.
Old Jan 8, 2002 | 12:08 AM
DavidM's Avatar
40/35psi (front/back). Though anything around 35psi works pretty well - so find out what works for you. If you don't want to do that then 35/35 is a good place to be.
Old Jan 8, 2002 | 12:30 AM
yellow2001's Avatar
32 psi
Old Jan 8, 2002 | 12:59 AM
Takashi KazuMori's Avatar
34F/34R PSI ... Just updated from my old 32F/34R settings which suited my drive better.
Old Jan 8, 2002 | 01:33 AM
getchastuff's Avatar
i run 38 psi front and 35 psi rear. seems to make the car a little stiffer and i feel that the car handles better that way. I can also swing the tail out much easier like this, which I really enjoy. Only drawback is that my rears were torched by 12000 miles.
Old Jan 8, 2002 | 06:36 AM
PLYRS 3's Avatar
instead of just throwing out numbers, shouldn't everyone also indicate what their wheel/tire set-up is?
i assume that 32 psi on a 16 wheel/tire combo would behave differently than on an 18 inch wheel/tire set-up.
or am i missing something?
Old Jan 8, 2002 | 06:51 AM
sorry about that. the 38psi front and 35psi rear are with stock wheels and tires. On a side note i recently switched to lm-22 winter tires in stock sizes and on those I am running 32 psi front and 31 psi rear. Any more tire pressure with the winter tires and the car gets twitchy at speeds above 80. I can't wait for spring and a fresh set of so-2's!
