what u use to change diff fluid?
Old Nov 14, 2001 | 06:24 AM
KaiWang's Avatar
Default what u use to change diff fluid?
For those of you that changed your own differiential fluid, what tool did you use to refill the diff? Is there some kind of pump like device for this?
thanks
Old Nov 14, 2001 | 06:31 AM
Prolene's Avatar
I use tubing and a bulb syringe. Fill the syringe, attach the bulb, squeeze, repeat.
Old Nov 14, 2001 | 06:34 AM
xviper's Avatar
I got a clear plastic tube (1-2 feet long) and pushed it onto the pointy fill cap (cut open the end first) of the oil bottle. Inserted the end of tubing into fill hole, raised the oil bottle as high as possible and squeezed the oil in till it ran out the fill hole. Duct tape the tube to the fill cap so it doesn't pop off.
Old Nov 14, 2001 | 06:43 AM
jpotts's Avatar
usually at the auto parts stores they have a hand pump with a 1-2 foot clear plastic tube. the top of the pump screws right onto the 75-90w gear oil bottles. I bought one at kragen for $10 or so. I haven't changed the s2000 diff fluid, but I have on my 4runner a few times and it works very well. xviper's tube method or the syringe will both work as well.
Old Nov 14, 2001 | 07:31 AM
txst's Avatar
I did the same as xviper - it was cheap, easy and not messy. This method also works when changing the transmission oil (except I slid the tubing onto a funnel, as the Honda MTF is sold in regular 1-qt containers).
Old Nov 14, 2001 | 10:34 AM
xviper's Avatar
[QUOTE]Originally posted by txst
[B]I did the same as xviper - it was cheap, easy and not messy.
Old Nov 14, 2001 | 03:24 PM
MarkS2K's Avatar
That's a nice use of some of the tools of your trade. Never thought it could be used that way.
[QUOTE]Originally posted by Prolene
[B]I use tubing and a bulb syringe.
Old Nov 14, 2001 | 03:34 PM
Radster's Avatar
I just go to Fisher Tire in Knoxville. It's easier this way, and I stand right there and watch the guy in the pit. They are very good people, and I don't have to worry about the disposal of fluids if I have them do it, which is an inconvenience in itself. Up to this point, I haven't let the car out of my site if I'm having anything done to it.
Old Nov 14, 2001 | 03:39 PM
RT's Avatar
RT
The pumps cost less than $5 and are made for the job, but then again, being creative can be fun too (just remember diff oil stinks so you don't want to be risking a spill).
cgper
Mar 24, 2016 11:11 AM
s2000maniac
Dec 17, 2012 01:51 PM
littlealex
Apr 3, 2010 11:18 PM
Silverstreak HX
May 8, 2004 01:11 PM
