What would you do about an OIL OVERFILL?
I am not quite sure where I should be posting this topic so it will be here in S2000 Talk as well as Under the Hood. Moderators do with it what you will if you feel necessary.
Being the anal retentive freak that I am, I was out in the garage last night looking over the car, checking fluids and such. I topped off my oil, seeing as it was down about 1-2 X's, but ended up adding a bit too much. The oil level now reads just above the top of the H. I did do a search on this subject and all it came back with were numerous threads about how you SHOULDN'T overfill your oil capacity. None of them specifically asked the question I am asking here.
In this situation what would you personally do about it?
I only have 1,800 miles on the car so I don't really want to do a complete drain and fill yet(break-in oil)...so what are my options?
Would you go ahead with the drain and fill and just say screw the factory fill oil with the supposed "break-in" additives?
Would you attempt to take a hose, stick it down the fill hole, and suck the third to half pint out of the engine somehow?
I just can't see myself under the car, unscrewing the drain bolt, allowing some to drain, and then attempting to put the drain bolt back in and screw it in before entirely too much drains out.
WHAT TO DO?
WHAT TO DO?
I would not worry about a couple onces
i guess the main danger is building too much pressure and blowing a head gasket...
definitely would not vtec with an overfill-
easiest way would be to use a pump that uses a hose- i know i have seen one somewhere recently for changing oil.
found it:
http://www.griotsgarage.com/catalog.jsp?&SKU=10122
found it:
unscrew the oil drain bolt slowly and when enough is poured out, make it tight again. i dont think replacing the washer is necessary, just make sure the bolt is tight(but don't overtighten, you don't want to strip the thread).
found it:
found it:
