What is wrong with this engine?
Old Jul 2, 2010 | 09:12 PM
morrobaybum's Avatar
Default What is wrong with this engine?
Ok so I am looking into buying my first S2000 and found a couple that might be what i want but one of the sellers sent me this photo and for some reason i feel like something is missing, any help? Also did the 03 BB every come with the tan interior or has anyone done a switch i think it might be a cool color combo.
Old Jul 2, 2010 | 09:18 PM
TAMTANIUM's Avatar
wrong section man..
and what is missing is the snorkel piece that goes into the intake box. He also changed the stock radiator hose to a blue one.
Old Jul 2, 2010 | 09:21 PM
oastjc's Avatar
hahaha
Old Jul 2, 2010 | 09:25 PM
Sinji's Avatar
missing the coil plug cover, the header heatshield, and the airbox has been modiied for a spoon snorkle(missing the scoop that goes there)
Old Jul 2, 2010 | 10:22 PM
B.C.'s Avatar
Those are aftermarket coilpacks. Coil plugs won't fit, unless you get new bolts. Radiator hose changed. Snorkle missing, front wind deflector missing. Aftermarket Battery. Weird red wire near the fuse box...
Both VIN # present on fender, just make sure they match the VIN on the car. If it does, no major accidents in the front end.
You'll need to check the Bajo Oil Bolts.. (Forgot which years and numbers, but 1/2 of AP1's) and change the Cam Tensioner.
And that's a useless strut car
Take it to a mechanic, dump the diff, and see if any abnormal metal shavings, do a compression check, and an leak down. If that all passes, you got a good car.
Old Jul 3, 2010 | 05:14 AM
Saki GT's Avatar
The red wire is not normal - he tapped into the fuse for something. Also looks like it has an aftermarket sound system.
Old Jul 3, 2010 | 05:49 AM
superchrgds2k's Avatar
Brake Fluid is black as hell too!
Old Jul 3, 2010 | 07:57 AM
fastD's Avatar
Where is the cruise control?
Old Jul 3, 2010 | 07:58 AM
fastD's Avatar
Looks like this may have FI then returned to NA?
Old Jul 3, 2010 | 09:01 AM
Kid Ap2000's Avatar
Look for something better dude trust don't go trew all that troble
