Whats Going on with my car!?!
Old Oct 8, 2001 | 12:39 AM
S2kVtec2's Avatar
Default Whats Going on with my car!?!
i have about 3600 miles on my car
ive been practicing my 7.5K launchs for a bit now and i think im getting the hang of it
all of a sudden today when i launched on stang my car just started spinning like mad and just revved up to 9k. the weird thing was i wasnt moving!
i tested it again around my block and the same thing!
what is going on?!?!!
are my tires just worn too much?
help me!
thanks in advance
dru
Old Oct 8, 2001 | 12:59 AM
2kturkey's Avatar
You didn't release the clutch quickly enough and span the clutch instead of the wheels.
Been there, done that (once) - it won't happen again.
Old Oct 8, 2001 | 06:28 AM
daves2k's Avatar
You have discovered one of the weak points in the S2000, the clutch.
If you do not step off the clutch at 7k (plus or minus) or if you step off at low rpm's the clutch will spin and you will literally stink up the joint. (Bet you smelled it burning)
Lots of threads here on clutches and what to do...do search and have fun.
Good Luck,
Old Oct 8, 2001 | 06:35 AM
Sunchild's Avatar
You do realize that you are destroying your car, right?
Old Oct 8, 2001 | 07:50 AM
xviper's Avatar
Some people have more money than ..............!
Old Oct 8, 2001 | 09:10 AM
Allan Haggai's Avatar
"How would you like your clutch sir... roasted or fried? May I recommend a side order of cracked differential?"
Old Oct 8, 2001 | 09:18 AM
Triple-H's Avatar
Yup, this is why I considered a used S2000 for about two seconds.
I'll be buying a new 2002 instead.
Old Oct 8, 2001 | 11:01 AM
S2kVtec2's Avatar
so how do i avoid this? just not launch?
dru
Old Oct 8, 2001 | 11:38 AM
Drop Top's Avatar
dru
Ok Bert. tell him what he's won!!
Actually, side step the clutch.
Old Oct 8, 2001 | 11:39 AM
xviper's Avatar
dru
At the present stage of aftermarket available replacements, YES. Of course, it's your car and you do whatever you like with it, but you must be prepared to replace some clutches and the possibility of a rear end, too. One day, somebody will produce a bullet proof (not the company) clutch and rear end for our cars. Till then, you can launch but not repeatedly and safely. A Mustang or Camaro makes a far better drag car but then, they corner like the Bismark by comparison.
