Whats a good spring w/o rear sagging?
Old Oct 2, 2005 | 08:49 PM
bumpinvtec's Avatar
Default Whats a good spring w/o rear sagging?
just like the title says, i want to know why do the eibach, espelir, rsr, etc. springs seem to make the back end look lower, is there a spring out there that drops our cars even all around, something in the 1.25 inch range?
Old Oct 2, 2005 | 10:39 PM
RazorV3's Avatar
im running kg/mm race springs and am also using koni yellow shocks. i set the fronts to be on the lower perch to make the drop even (actually its not 100% even, the front is a tad bit lower than the rear). it looks really good and doesn't have that "boat" look. anyways, the kg/mm race springs would make the rear lower too if I just ran it with stock shocks.
so your options are to either get koni yellow shocks (adjustable height perches) OR go with a full coil-over system. you can also run groundcontrols on stock shocks if you want to precisely adjust the height.
Old Oct 2, 2005 | 11:54 PM
vampire's Avatar
my fronts are lower than the rears with the tein s-tech
Old Oct 3, 2005 | 08:43 AM
bumpinvtec's Avatar
any other springs besides the tein's, do you have a pic of your car on teins, anyone know how the H&R springs are
Old Oct 3, 2005 | 09:32 AM
MmphsS2000's Avatar
I have seen some springs that say that the drop in back is lower than than the front, why is that? I would think you would want the front to be lower?
I thought the Espelir springs were supposed to be 1.3" all around?
Old Oct 4, 2005 | 10:46 AM
rajun asian's Avatar
H&Rs with stock shocks.
After about a year and a half.
K.Shift
Sep 28, 2010 07:39 PM
Driv300mph
Jul 1, 2006 12:13 PM
honda138
Dec 27, 2004 06:21 PM
RazorV3
May 11, 2004 07:15 PM
wreckeds2k
Jan 28, 2004 07:32 PM
