What's the pressure?
Old May 5, 2004 | 09:52 AM
wai_ster's Avatar
Default What's the pressure?
The tires on my 02 S2k says 40psi the manual says 32psi. Far as i know these are factory tires. Anybody?
Old May 5, 2004 | 10:01 AM
Intrepid175's Avatar
As far as I know, what's on the tire is the "maximum" allowable cold tire pressure. In theory, the 32psi that the manual states is Honda's recommendation that's best for the S2000 application.
I'm sure someone else will give you better information here. For the time being, I'd use Honda's recommendation as a minimum cold pressure.
Drive Safe,
Steve R.
Old May 5, 2004 | 10:03 AM
cyber_x's Avatar
I've used 32 psi (cold) for both stock and aftermarket tires on my '02.
Old May 5, 2004 | 10:21 AM
Z06-KILLR's Avatar
It depends what type of driving you do. I keep about a 38 up front and a 34 on the back...I have S02's but I also have quite a bit of negative camber and drive the PISS out of it
Old May 5, 2004 | 10:26 AM
Cayenne_S2000's Avatar
That sounds about right. I usually go to ~38-40 psi on S03s for my 911. The max pressure for the SO3s (265/35 18") is ~45psi.
Old May 5, 2004 | 11:05 AM
Woodwork's Avatar
There will never be closure on this debate (Ford/Bridgstone).
The car company wants the best ride, best grip and a distant third is the tire wear, and to not sacrifice safety.
The tire company wants the best tire safety (low heat) and is least concerned if your fillings are coming loose.
Anywhere between the car specification and the tire specification is ok, If I'm going to be on a long drive I usually inflate them to the tire specification, this will make for less heat (sidewall flex) If I'm doing the commute I use the car specification (softer ride). If I'm going to be on the track I usually listen to those who know the track and adjust from there.
HTH,
woodwork
Old May 5, 2004 | 11:40 AM
E36Ap1's Avatar
I ran with high PSI but it kills the center of tire since the tires tend to plump out. The inner section of tire wear greater because it would be plump. The car handle better but hurt the ride. Now I just keep a mild setting for my tire pressure. I do believe it all on you on what you want on how much tire pressure you want to put to your car. Right now I prefer to run about 34 front and 32 rear.
Old May 5, 2004 | 12:51 PM
Icemn2003's Avatar
I asked Jim from the Tire rack, he recommends 32 psi on aftermarket tires as well as OEM.
Old May 5, 2004 | 06:55 PM
RazorV3's Avatar
xviper recommends 34-35 psi for a good sacrifice b/w ride comfort, handling and tire wear.
Old Jun 2, 2004 | 10:03 AM
foolio's Avatar
HTH,
woodwork
Woodwork tracks his car?
