Wheel question?
Old Apr 2, 2001 | 05:23 PM
TurboVtk's Avatar
http://www.axiswheels.com/se7en1.html
I was looking at this rim ( the 3 piece format in gunmetal at the bottom left conner) but on 18's the width is 7.5, i was wondering if anyone knows if they come in 8.0 and if not can you fit 255-35-18 on this type of width 7.5 or do you need to be 8.0, also the offsets are marked on this page if you scroll down, does it match the off set needed for the s2k? would 19" fit an s2k? and what are the recommended wheel sizes and wheels?
Old Apr 2, 2001 | 05:38 PM
shingles's Avatar
you should *definately* not put 255's on 7.5" rims. Considering that most 235 calls for 8" wide... I don't think putting 255 on 7.5" is good at all.
-Shing
Old Apr 2, 2001 | 05:40 PM
RT's Avatar
RT
[QUOTE]Originally posted by Typer_00
[B]http://www.axiswheels.com/se7en1.html
Old Apr 2, 2001 | 05:45 PM
TurboVtk's Avatar
285 ins that too much, so would you look at the link again and tell me if i go 17's is it doable? thanks
Old Apr 2, 2001 | 06:03 PM
RT's Avatar
RT
OK, these are minimum numbers for required offset and will differ depending on tire size and brand (more offset required if you plan to shoe horn on a tire that is too wide for wheel)
Widths regardless of diameter:
Front
7" need at least 42mm
7.5" need at least 49mm
8" need at least 55mm
8.5" need at least 61mm (getting pretty tight on inside)
Rear
7.5" why bother
8" need at least 45mm
8.5" need at least 51mm
9" need at least 58mm
9.5" need at least 64mm
10" need at least 70mm
10.5" need at least 76mm (getting pretty tight on both inside and outside)
These numbers are for no rubbing and full suspension travel.
I know plenty of the people here have "not enough offset" and no problems but you may as well do it right if you haven't already done it wrong!
Old Apr 2, 2001 | 09:18 PM
TurboVtk's Avatar
thanks, you saying i cant use this wheels then right, if i go 17's which tire sizes will i need to use and do these have the offset?
Will these in 19 fit and what will be the tire sizes
migurushiimitai
Dec 19, 2009 11:56 AM
alexchou
Jan 29, 2008 06:58 PM
jbell
Oct 6, 2006 01:13 PM
AustinS2k2003
Jan 8, 2004 07:54 AM
Domino
Feb 15, 2002 04:18 AM
