Wheels from NSX and TL fit?
Old Jun 11, 2001 | 11:27 AM
shingles's Avatar
Default Wheels from NSX and TL fit?
I know a couple months(?) ago, someone put their TL rims on the S2K and the S2K on the TL... so this would imply that aftermarket rims for the TL would fit on the S2K... also the subject of NSX rims on the S2K would imply the same... I did a search on tire rack for NSX rims and came up with a lot more options than with an S2K search... the TL search was the same... except TL results might not have rims with different FR sizes. Anyways... I was just wondering if there's confirmation on the NSX fitment...
-Shing
Old Jun 11, 2001 | 11:29 AM
mingster's Avatar
Socal28 has his TL wheels (aftermarket wheels) on his S2K. Looks good.
Old Jun 11, 2001 | 11:57 AM
Phantom's Avatar
[QUOTE]
Specs from Acura site:
Front Wheels NSX 3.0: Forged aluminum alloy - 8 JJ x 16
Old Jun 11, 2001 | 11:59 AM
Phantom's Avatar
[QUOTE]
Old Jun 11, 2001 | 12:38 PM
ST's Avatar
ST
I pulled this from NSX Prime FAQ:
What Are The OEM Wheel Specs?
Sizes
1991-1993 Front: 15" x 6.5"
1991-1993 Rear: 16" x 8"
1994-Present Front: 16" x 7"
1994-Present Rear: 17" x 8.5"
Lug Nut Torque Spec
The torque spec for the factory lug nuts is 110 N.m (80 lb-ft) for all years.
Factory Offsets
The NSX's front offset is 55mm and the rear is 60mm for both the 15"/16" and 16"/17" wheel sizes.
The NSX's front wheels fit the 97 Preludes (and 3.2 TL's) in either 15 or 16 sizes. Lock your wheels!
Center Bore
The NSX's proper centerbore is 70(.1)mm front, 64(.1)mm rear.
Factory Bolt Pattern
The NSX has a 5-bolt pattern with a 114.3mm bolt circle.
Lug Nuts
OEM wheels use a 19 mm lug nut. Thread pitch of 12 mm x 1.50
Originally posted by Phantom
If in fact the rear NSX 17x8.5 is +60mm for offset...it will fit perfectly.
If in fact the front NSX 16x7 or 16x8 is +55mm for offset...it will fit perfectly.
Someone call Acura to confirm the offsets...
I pulled the offsets from this post:
http://www.s2000online.com/forums/showthre...?threadid=17580
Old Jun 11, 2001 | 12:54 PM
Phantom's Avatar
[QUOTE]
Old Jun 11, 2001 | 01:16 PM
shingles's Avatar
[QUOTE]Originally posted by ST
[B]I pulled this from NSX Prime FAQ:
Sizes
Old Jun 11, 2001 | 02:33 PM
Pepe's Avatar
[QUOTE]Originally posted by Phantom
[B]
Cool...
If they retained the +55mm front and +60mm rear for the 16x8 and 16x7...those wheels would fit great!
Now lets see how much those wheels weigh, and how much they cost.
Old Jun 11, 2001 | 03:28 PM
ST's Avatar
ST
Yeah, still alive and kicking Just don't have much time for the message board and stuff anymore
Been killing myself trying to find an E46 ///M3 at around MSRP, but have yet been unsuccesful. In the interim, I'm enjoying my time with the Stook, until she goes
[QUOTE]Originally posted by shingles
[B]
Damn ST, you are still alive!
Old Jun 11, 2001 | 03:35 PM
ST's Avatar
ST
I could only find info on the 15"/16" combo with tires:
Stock 15"x7" Front Yoko A022H (stock) 32 lbs.
23"
Stock 16"x8" Rear Yoko A022H (stock) 44 lbs.
24.5"
[B]
Cool...
