When I flash my highs, HIDs come on as well
saki,
can you explain this a little further?
"That's why you'll see on high end cars like Porsches, the HIDs move to change patterns from high to low rather than have separate lights."
do you mean the actual aim or alignment of the lights physically move higher or lower with the flick of the control? I would think that that would be slower but i dunno.
thanks
thanks
Originally Posted by matthewsolo,May 2 2009, 01:28 AM
saki,
thanks
thanks
I have an older Porsche 986 with factory litronics. The high beam is still halogen and the xenon low beam doesn't come on when you flash the highs. However, my headlights do have a motor in them and when I turn on high beams a motor moves the low beam projector slightly upwards so that the low beam pattern compliments the high beam.
Originally Posted by roflitzjinno,May 2 2009, 12:56 PM
they should have it cut off the power to the low beams. in my moms crv it switches the power to just the high beams when you flash it. then when you let go of the stalk the low beams come back on.
Even cars with Bi-Xenons have halogen high beams. If the HIDs are off, it will still take too long for them to warm up, bi-xenon or not. Halogen high beams will light up immediately.
My Bimmer has both bi-xenons and halogen high beams. If I pull the stalk back, for flash to pass, the separate halogen (inner) lights will go on. If I push the stalk forward, for prolonged high beam use, the HID cutoff shields are flipped up and the halogen high beams don't light up.
BTW, the bi-xenon "high" beam is significantly brighter than the halogen flash-to-pass beam.
Here's a video of it:
http://www.youtube.com/watch?v=19C1uaAYQKk
... which is the point of this thread. So again... answer the question - why do our cars' HIDs turn on with a high beam flick, when the stalk is set to off or parking lights only?
As per my post, I'm pretty sure all Hondas/Acuras do that. Even my Subaru does it. I've seen other cars that turn the low beams off when the highs are on but not Hondas.
