where to get cheap oil
Old Oct 8, 2005 | 12:14 PM
LivingLegend's Avatar
Default where to get cheap oil
I need to do an oil change and the last time i did it myself i spent $33 for 5 bottles from Kragen. It seemed alot to me, is there anywhere else that i can get it cheaper?
Old Oct 8, 2005 | 12:31 PM
Nice-Face's Avatar
I certainly hope you meant "where to get oil cheap" rather than "where to get Cheap Oil"..hahh..big difference right there
Old Oct 8, 2005 | 12:37 PM
afwfjustin's Avatar
Walmart carries 5 quart containers of Mobil 1 Synthetic for 20-22 dollars.
Old Oct 8, 2005 | 12:43 PM
yarou's Avatar
halvoline 10-30 GF-4 is about 1.40 a quart at walmart
https://www.s2ki.com/forums/index.php?showtopic=282207
Old Oct 8, 2005 | 01:14 PM
JohnR_in_la's Avatar
Do S2000s eat much oil? I hear they eat some ...but not as bad as other sportscars?
Old Oct 8, 2005 | 01:17 PM
I always do mobile 1 syn every 3500 miles.
Old Oct 8, 2005 | 05:56 PM
Wisconsin S2k's Avatar
mobil (no "e") 1 syn every 3500 miles is a waste. you should be waiting AT LEAST 5000 miles with a synthetic.
but, if you insist on 3500 miles, switch to havoline GF4. it's just as good if not better than mobil 1, and it costs less too.
Old Oct 8, 2005 | 06:40 PM
reds2's Avatar
Costco is about $24 for 6 qts of Mobil 1 synthetic.
Old Oct 8, 2005 | 07:56 PM
s2kin06's Avatar
Not always... oil still gets dirty with even the best of filters and needs to be changed, even with synthetic oil should be changed within four thousand miles. I took this advice from my friend who works at an oil change place. I went for about 3700miles once and when he looked at the oil he was like, "yea this needs to be changed" (it was pretty dirty). If you can go for a while without your oil getting dirty then go ahead. But just check the color every now and then to make sure that its not getting too dirty.
Old Oct 8, 2005 | 08:16 PM
ItsBen's Avatar
Is it ok to mix different brands of oil? My oil is running low and I don't know what brand the dealer used to change it. Its 10w30 so can I buy a quart of halvoline and add it in?
