Whoa!
depends how lose it is. its entirely possible that you won't get full throttle if its too lose.. the pedal only depresses so far, and therefore, it can only pull the cable so much.
I imagine on most cars, you will have ~1/4 inch deflection when the cable is adjusted almost all the way tight (i.e. you're almost out of threads)
Originally Posted by AlwaysBoosted,Mar 4 2007, 10:57 AM
i did this to my 2K as well as my friends 2K. And I would have to say it did make a difference in throttle response. 1st gear no bog what so ever, and I have a competition stage 4 clutch and bog use to be my best friend and 1st gear was always a PITA but now its remarkably better IMHO. good adjustment
When the factory assembles the car the throttle cable is loose (has a play). If those bolts come loose from milage it would be very little change. The bolts lock eachother into place so they should not come loose.
Originally Posted by Eluded,Mar 4 2007, 06:56 PM
I have an 06 and just just checked my throttle cable. Sure enuf it was WAY out of adjustment. The difference is AMAZING. Thanks for the tip!
