Why Don't My Dome Lights Work
Old Apr 30, 2009 | 07:48 PM
sandiegan's Avatar
Default Why Don't My Dome Lights Work
My dome lights don't work right. Once in a blue moon, when the stars and the moon are properly aligned, the lights will come on after I turn the car off and pull the key out, but they usually turn off after about 10 seconds. They never work when I try to turn them on myself, and do not turn on when I open the door. I have replaced all fuses and bulbs, and as mentioned they do sometimes sporadically come on. Any ideas on how to diagnose?
Old Apr 30, 2009 | 08:07 PM
detonator2x's Avatar
Mine don't seem to work with the switch in the middle position when I open the door. They're supposed to come on at that point right? They come on when I toggle the switch to the "on" position however.
Sorry, not trying to thread jack, just adding to. Hopefully both our situations can get answered
Old Apr 30, 2009 | 08:40 PM
klee1113's Avatar
check the contacts.. mine werent working too i took it apart and there was this paste type substance that was messing with the contact points..
dried it off and fixed the problem
Old Apr 30, 2009 | 09:09 PM
ahrmike's Avatar
^Its from a leaky soft top. Clean it off, scrub it with something mildly abrasive, then put a little oil on it to prevent further corrosion - something like WD 40 might work.
Old May 1, 2009 | 06:45 AM
vtec9's Avatar
I think the dome lights on MY00 cars have a mind of their own. I swear mine do whatever the hell they want, most of the time that includes not coming on
Old May 1, 2009 | 06:59 AM
leets's Avatar
Banned
It's the contacts. Just need to rip the thing apart, clean them up, and slap it all back together.
Old May 1, 2009 | 07:47 AM
FitzyS2k's Avatar
also check the contacts inside the door sills. mine stick once in awhile too.
Old May 1, 2009 | 01:38 PM
gedupsound's Avatar
I was lucky enough to just have it start working again all of a sudden
been good since. throw that in the how-to DIY list of things to do.
Old May 1, 2009 | 02:11 PM
sandiegan's Avatar
Hallo Thar!
Is everyone referring to the contacts between the bulb and the dome fixture? Or do I have to pull everything apart and clean something else up. I tried cleaning where the bulbs go with some Simple Green and a sock, but it was dark in my garage, and it was 1230AM. Needless to say, it did not work, not with the button, and not with the door open I am going to try a cue tip and some rubbing alcohol next time
Old May 1, 2009 | 02:24 PM
leets's Avatar
Banned
Originally Posted by sandiegan,May 1 2009, 02:11 PM
Hallo Thar!
No, I was referring to the contacts for the switches, inside the housing. I have some pics somewhere of when I did it. I'll try to find them and post up a DIY.
