Will Honda install additional relay?
Old Apr 2, 2003 | 02:56 AM
Ajjra's Avatar
Default Will Honda install additional relay?
My car is at the dealership today and I'm wondering if they will install the driver's side window relay on the passenger side, allowing the passenger side window to "auto-down"
Anyone tried this or know if it would work? Any guesses on the chance that Honda will or will not do this?
Old Apr 2, 2003 | 03:10 AM
Jason B's Avatar
Why give your passenger all the convenience?
Old Apr 2, 2003 | 03:12 AM
Ajjra's Avatar
Why not?
It has auto-down when you put the top down, so I'm not sure why they didn't just use the same relay....
Old Apr 2, 2003 | 03:27 AM
Austblue's Avatar
If they dont do a search there's a diy for this mod somewhere.
Old Apr 2, 2003 | 03:30 AM
djohnston's Avatar
They won't fix it if it ain't broke. Replacing the regulator means tearing apart the door panel and removing the glass, not exactly a repair they do lightly.
Old Apr 2, 2003 | 03:48 AM
Jason B's Avatar
Probably the same reason why you can't unlock the passenger door after you are in the car from the driver side switch. You have to reach over which is dumb.
Old Apr 2, 2003 | 04:44 AM
STL's Avatar
STL
It's not just a plug-and-play thing so it's not going to happen! Even it was plug-and-play then I still doubt they would do that for you.
Old Apr 3, 2003 | 11:40 AM
andrewewing's Avatar
It's not just a relay. The window switch is different. The left switch goes part way and then you overcome some resistance and push it further for auto-down. This undoubtedly means an extra switch contact which means an extra wire would have to be run, etc. In other words not a simple job.
sexysilvers2000
Sep 4, 2018 04:01 PM
RHIT_S2000
Jun 2, 2016 10:27 AM
rai
Dec 12, 2005 02:25 PM
ghoward11
Jun 2, 2005 12:41 PM
dhayner
Jul 8, 2004 08:44 AM
