will i be able to fit 19s on my S?
Old Aug 13, 2005 | 08:23 AM
twofast4u's Avatar
Default will i be able to fit 19s on my S?
u read the topic fill me in
Old Aug 13, 2005 | 08:50 AM
jwa4378's Avatar
Speedometer will need to be re-calibrated for sure. Also, rubbing might be an issue. 19's are usually wider wheels, as well, so they might not fit under the rear fenders if they are too wide or have too large of a lip. Ride quality will also most likely go to hell because of the tiny tires. Acceleration will also suffer due to rotational inertia.
John
Old Aug 13, 2005 | 09:01 AM
allkingz's Avatar
If it looks goofy, you'll get laughed at
Old Aug 13, 2005 | 09:03 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Sky is the limit!!!Go 22".
Old Aug 13, 2005 | 09:53 AM
s2000flog's Avatar
stick with 18's my man.... 19's will look GHETTO!!!
Old Aug 13, 2005 | 10:13 AM
s2000flog's Avatar
For ExampleMy Webpage
Old Aug 13, 2005 | 10:53 AM
koala's Avatar
Speedometre will read correctly so long as you plus size your tires properly.
Performance will suffer significantly as all of the wheel weight is being pushed further out away from the hub.
Terrible idea if performance is any concern of yours.
Old Aug 13, 2005 | 11:03 AM
jwa4378's Avatar
I was told that you can only go +2 sizes on the tires, because there is no 19" tire that is the same diameter, when mounted, as the stock 16's. 18's can get away without re-calibrating, but 19's probably not.
You might be able to go with a 30 series tire, but that low of a side wall would increase risk of bending rim on potholes.
John
Old Aug 13, 2005 | 11:11 AM
koala's Avatar
[QUOTE=jwa4378,Aug 13 2005, 01:03 PM] I was told that you can only go +2 sizes on the tires, because there is no 19" tire that is the same diameter, when mounted, as the stock 16's.
Carsun757
Jun 30, 2016 11:02 AM
User 111717
Feb 13, 2014 02:21 PM
cheddaboy
Jan 14, 2014 10:40 AM
golubS2K
Dec 12, 2013 09:03 AM
flipdsm
Jul 9, 2009 11:07 PM
