will i go over 9K?
Old Oct 20, 2008 | 04:24 PM
AeroS2000's Avatar
Default will i go over 9K?
if i floor it to 9K and just hold the throttle there will the engine rev over 9K. havnt really got to 9k yet but i vtec all the time.
Old Oct 20, 2008 | 04:33 PM
vtec ftw's Avatar
No, the car has a rev limiter that either cuts the fuel or the spark, I'm not sure which, but you'll know when you hit it.
The only way to go past redline is to downshift into the wrong gear causing a mechanical over-rev, which will damage your engine.
Old Oct 20, 2008 | 04:35 PM
mlc's Avatar
mlc
In that case you will hit the rev-limiter. You can bump it for a second or two but if you don't shift it will basically cut the gas for a second or two. When you see the red lights kind of flicker it is time to shift. Try it, you will like it. You really haven't lived until you bump the rev-limiter.
mlc
Old Oct 20, 2008 | 04:39 PM
hariku821's Avatar
Hitting the limiter sucks
Old Oct 20, 2008 | 04:42 PM
mlc's Avatar
mlc
There is a difference between hitting the limiter and bumping the limiter. You can bump it for a second or two. But if you hit it, it does suck.
mlc
Old Oct 20, 2008 | 05:27 PM
caiock's Avatar
i always change when the red light flashes
Old Oct 20, 2008 | 05:51 PM
JERO's Avatar
The engine will not cut out until the third redline flash. Still, with an AP1 the tranny gearing matches the engine as Honda desired it to. Soooo you can shift well short of redline (like say 8600 or so) and you will always up shift into the VTEC band. AP2's have to speed shift at redline and slip the clutch in order to stay in VTEC.
AP1 FTW
Old Oct 20, 2008 | 06:24 PM
Sr2oD3's Avatar
actually, fuel cut is at 9200rpm. Not sure why you wanna go that high unless you're on a tight autocross course...
Old Oct 20, 2008 | 06:37 PM
JERO's Avatar
Are you sure about the 9200? I thought I read on here that when using ecu management systems the stock fuel cut off is actually a hair shy of 9,000. Something like 8990 or something?
Old Oct 20, 2008 | 06:48 PM
dparm's Avatar
The fuel cut is almost always above the redline.
Only way to pass 9000rpm is to mechanically force the engine to go that fast...meaning a mis-shift.
