windshield replacement......
Old Mar 2, 2005 | 07:30 PM
moonwalker's Avatar
Question windshield replacement......
i just had a huge crack on my windshield.....i went to to the dealership they asked for $700 for parts and installation..........
then i went to another local bodyshop.......they could do it for $350 totally.......but not with Honda oem windshild.......(my insurance dont cover my windshield....so im condering the cheaper offer)
so do u guys know if aftermarkets windshield has the same quality as the OEM ones......anything special about our oem windshield??? or any cautions i have to about other aftermarkets windshields???
thanx........
Old Mar 2, 2005 | 07:46 PM
SilverKnight's Avatar
honda stealerships. Its the labor not the part that kills you.
Try this: Buy the OEM window online then go to any glass place ot have it installed. Or have the dealer order it and do it at a cheaper place. Nothing beats OEM
Old Mar 2, 2005 | 07:47 PM
BTW was it a huge crack at first or did it gradually start to get bigger? If so should have got the crack fixed.
Old Mar 2, 2005 | 08:26 PM
Ckcrigger's Avatar
Just get aftermarket. No difference. And it will need replacing from little rock chippies in a couple years anyway. Just make sure the auto glass place puts it in well with no stress flexing or it can break with minimal additional stress.
Old Mar 2, 2005 | 08:33 PM
Saki GT's Avatar
There's only PPG and Safelite brands right? OEM is PPG, but people get both types of glass installed for their S - its important that they do a good job installing it though. Call around and see if you can get a lower offer.
Old Mar 3, 2005 | 01:39 AM
NNY S2k's Avatar
After mine was hit with a large stone from a truck I had to have mine replaced. Had it fixed at a local windshield place with ppg, mine was covered by insurance though. I don't notice any differance between my original glass and the current windshield.
Old Mar 3, 2005 | 04:52 AM
mosesbotbol's Avatar
I had my windshield replaced by JN Phillips and they are basically the same. Unless you're looking for a 100 point show car, they are identical products. Make sure the installation is done well. The outer seal around my windshield could've been adhered better.
I would rather have a glass place do than the dealership just because your recourse will be better with a glass place. How many windshields does the dealer install (if they even do it themselves or just sub it out to a glass installer).
Old Mar 3, 2005 | 07:06 AM
lukemc01's Avatar
Make sure you get PPG though... They are the OEM suppliers for Honda in the US - not sure about S2000s because they are manufactured in Japan. My friend had the windshield of his Corvette replaced by Safelite. He had to return 4X. They make their own windshields - his was pretty distorted, enough to give him headaches. They also installed it using butyl caulk (which is illegal in CA) and tried to reuse the original seals. When my friend took it back because of the major leaks, they replaced them with a cheap aftermarket one. Add to the fact that Safelite is the "Supercuts" of windshield repair (Newbies get a lot of "on the Job Training") I would avoid them all together.
Wherever you go, its worth it to get a PPG windshield, and make sure they use genuine Honda seals. The guys who replaced mine used genuine seals and PPG glass. They showed up at my driveway and finished in about 30 min. Icalled the two local Honda Dealers and the local independent Honda service center for recommendations. They all recc'd the place I eventually went to. So ask around.
Old Mar 3, 2005 | 07:32 AM
dhayner's Avatar
Most dealers won't install the glass themselves anyway. They'll have it done by a replacement house and charge you a markup. Go to the replacement house yourself and save money. If you insist on OEM glass, they'll get it from a dealer.
Old Mar 3, 2005 | 09:53 AM
SB2007's Avatar
Mine was replaced with a PPG windshield at a local body shop for $300 installed...
