$850 problem solved for $11
My dealer told me they had to replace my ECU after a check engine light (scan read random misfire/ok to drive). Then they changed it under warranty and it didn't help. Then they said they had to clean my injectors (paid $90)... didnt do anything... then they said they needed to replace my fuel injectors (for $850, but didnt have it done)!
I wondered if maybe it was just a loose gas cap... they said no. SO- I get my NJ car inspected yesterday- and failed. They said I had a faulty gas cap, wasn't getting proper pressure. Got a new cap, check engine light is off. Problem solved for $11.
Thoughts?
Thoughts?
That's what I was thinking. But it said OK to Drive along with misfire, so maybe thats a "soft code" that doesn't need repairing? All I know is the car drives great and the check light is off. One mechanic said I should replace my plugs but they shouldn't be bad yet (50k on the car)
I'm trying to get my 91 Civic through NJ emissions and I failed. The check engine light was on for the fuel injector circuit. I checked the fuel pressure, regulator, injector resistance, and injector fuel pressure drop and everything was OK. It turned out to be a faulty ground at the thermostat housing that eventually got rid of the engine light.
Of course I could have worked like a dealership and replaced everything first then fixed the ground cable.
It's sad how badly the dealer tries to rip you off.
About the plugs... why would they need replacing, though? I guess the misfire is SLIGHTLY noticeable in 2nd gear and a slight rough idle sometimes.. but not worth $850 for injectors. What should new plug replacement cost installed? (Believe the dealer never even recommended plugs with a MISFIRE code??)
mightykang
Oct 18, 2006 02:03 AM
