*IN PROGRESS* OEM top replacement DIY for MY02+
Very nice write up. I'm just 'starting' mine, about 5% in with the interior off. The top looks a little menacing, don't really understand the whole movement thing
Then again I haven't really been around my car all that much. Good job!
You mention other DIY's, ive been searching and reading as much as i can before tackling this and wanted to know if you would link to the others, incase i missed one.
Thx for the tip on not cutting the straps at the back, the problem is that i knw at least 1 of mine has snapped and been re stiched by ????? before i got the car. Do you have any advice on it before i start the procedure?
my list contains extra rivets, screws, padding, tape and apparently velcro, for this billman fx i need to read about still. Might do the modifry traps also after more research.
You are quite welcome. Doing the documentation didn't add much, so I just did it. Glad it has inspired more people to do their own tops as it really isn't very hard.
I bet the top-changing industry is quite unhappy with me though
Awesome diy....I'd like to add to it....
When working with the two bows that hold the top....don't pry them open. Slice the top with a razor, and slide them out the side.
Once you lift those bows, they crease and never go down right.
Cut...no pry
best top diy I've seen.
Cut...no pry
