* Quick Fluid Reference Guide & Oil Journals *
Originally Posted by news2kroller,Feb 7 2006, 02:35 PM
Im sort of confused about the diff fluid. I have 4.56 gears and im about to change out the fluid that ramjet put in there for another brand as im almost done with the break in period. i live in so cal so the tem range is usually 55-80 from winter to summer, I always warm up my car before driving it hard or even fast, i have about 5-7 mins of driving under 40mph when leaving my neighborhood, and i think that would be adequate to warm up the diff fluid. Someone mentioned problems with the le607 and that was the fluid i was going to go with but i would like other reccomendations if theres another fluid that suits my needs better than the le607. thanks.
CHRIS
CHRIS
Originally Posted by slimjim43,Feb 8 2006, 05:54 PM
I change my oil every 3K miles due too a lot of short distance driving. At 3K my oil is pretty dirty. Any of you guys experience dirty oil at 3K?
Originally Posted by Hockey,Feb 8 2006, 06:23 PM
Dirty according to what criteria.....looking at it, or a used oil analysis (UOA)?
All oil will "look" dirty when it is doing its job. Getting a UOA will break down the contents of your oil and tell you if it is doing its job - and if your change intervals are correct or need to be adjusted.
-Hockey
-Hockey
Originally Posted by jimi,Feb 8 2006, 04:51 PM
There's no way I'm leaving any oil, no matter what type/brand in my car for 10K mi. That's just ridiculous. Where does all the dirt from 5.1 qts of oil go Into the oil filter?
Originally Posted by WyattH,Feb 8 2006, 07:26 PM
Is the PacNW too cold for LE607? It ranges from 40-85 degrees.. RARELY is it below 45, though. And the car is garaged if that makes a difference.
