00-05 vs 06-09 ABS Sensor Compatibility
Old May 5, 2016 | 09:26 AM
nitewing117's Avatar
Default 00-05 vs 06-09 ABS Sensor Compatibility
Hi,
I was changing my wheel bearing and made the mistake of not unhooking my ABS line before popping the rear upper ball joint. Unfortunately, it completely tore the wire off the ABS sensor once it separated.
Looking at the parts catalog, the part numbers between 00-05 and 06+ are nearly the same:
57475-S2A-003 - 00-05
57475-S2A-013 - 06+
Most of the used sensors that I can find are either from an 00-05, or are (incorrectly?) listed as 00-09... I don't want to buy them and find out that the parts are incompatible. The dealer was unable to give me any clues on the compatibility either.
I was wondering if anyone had any experience with using a 00-05 ABS sensor on an 06+ or had a driver-side rear sensor that they wouldn't mind me returning if it didn't work out?
Old May 5, 2016 | 10:22 AM
yessamgerg's Avatar
If Honda changed a part number there is definitely a reason for it, they don't even change part numbers when they steal parts from other cars (some of our eccentric camber adjusting bolts have NSX part numbers). With that said the part number change could be as simple as a material change on on of the rubber bushings that is used to mount the wire to the CA. Honestly it's a toss up and I wouldn't be shocked either way. Do you know if the ABS module on the cars with VSC is still made by nissin?
Old Dec 27, 2020 | 06:15 PM
Soviet's Avatar
If anyone is wondering. The connector for the rear ABS wiring harness which plugs into the rear chassis wiring harness is different for 00-05 and 06-09. They are not compatible, I tried.
Old Dec 28, 2020 | 05:33 AM
randomwalk101's Avatar
Thank you. I think you can just cut off the 00-05 connector and solder it into the 06-09 one ?
Old Dec 30, 2020 | 01:44 PM
Soviet's Avatar
I'm not sure. The wire colors are different between the years, but I'm not sure if that means anything.
nitewing117
May 1, 2016 04:38 PM
Jimbowang
Forced Induction For Sale
May 1, 2015 07:21 AM
evil MS3
Oct 7, 2012 07:36 AM
smithengineered
Nov 7, 2011 06:59 PM
lewiS2K
Oct 7, 2009 12:17 PM
