01 s2000 misfire
Old May 5, 2013 | 12:57 PM
  #21
I_s2k1's Avatar
Awesome will try that thanks for this help by the way much appreciated
Old May 5, 2013 | 03:26 PM
  #22
Murphg05's Avatar
keep us posted!
Old May 5, 2013 | 03:31 PM
  #23
apme123's Avatar
take apart the IAC valve and clean it, do a compression test how hard can it be???
Old May 5, 2013 | 04:51 PM
  #24
I_s2k1's Avatar
@apme123 pretty hard actually when u dont have a compression tester and ur work schedule is only the times the shops are open already have shop who will do it for free just my timing is horrible
Old May 5, 2013 | 10:15 PM
  #25
apme123's Avatar
let us know
Old May 6, 2013 | 05:14 PM
  #26
I_s2k1's Avatar
I just did a compression check cylinder 2 is at about 110 and cylinder 4 was 230lbs bent valve or deeper?
Old May 6, 2013 | 06:41 PM
  #27
apme123's Avatar
add a tiny bit of oil into cyl 2, about a tea spoon or cap full, if the compression goes up then the cyl wall has damage, or the piston ring is gone, of the compression remains the same, I would try a valve adjustment, if the does not help, then its very possible the valve is bent. Add a cap full or teaspoon full of oil and redo the compression test. Let me know what you find.
Old May 7, 2013 | 04:43 PM
  #28
I_s2k1's Avatar
So i couldnt do the compression today but im checking with a feeler gauge on the valves. The .008 on the feeler goes in pretty freely on cylinder 2 intake side. Exhaust side the .008 has a little friction to it.
Old May 7, 2013 | 05:42 PM
  #29
apme123's Avatar
make sure cyl 2 is at tdc
Old May 7, 2013 | 05:46 PM
  #30
apme123's Avatar
I am on my phone I don't remember the specs. look them up on this forum
