04' engine in 03' s2k
I'm planning on purchasing an 04' engine and i was wondering what else would i have to change to make it work with my 03' s2k. It's comming with an ecu but will there be any major mods i'll have to change on it for it to work?
What happened to the 03' engine?
I have also heard in this post, that you need to modify how the fuel line connects.
Even though this is if it's possible for it to rev to 9k it does talk about a lot.
https://www.s2ki.com/forums/index.ph...ic=254276&st=0
soozookabluS2k : the 04 tranny is not that much different. I think it was figured that it's only 100 rpm difference.
S2000 Europe: I thought there were more differences between the 2.2l and 2.0l than just a crank. I thought the pistons were also different, which if that's the case wouldn't be suprised if the rods were different also.
2004 Specs
2002 Specs
