05 won't start
Old Oct 31, 2015 | 03:34 AM
airintake0_0's Avatar
Default 05 won't start
I bought a wrecked 05 and can't get any spark. Both air bags went of and theres not a straight panel on the car. Is there any crash sensors that keep it from running that need to be reset. I just want to hear it run before I pull the motor.
Thanks
Old Oct 31, 2015 | 05:15 PM
Anybody, I checked all the fuses and put a code reader on it but nothing comes up as its been sitting with a dead battery for a long time.
Old Oct 31, 2015 | 05:32 PM
windhund116's Avatar
You getting any signs of electrical life, with a new battery? Dash lighting up?
Old Oct 31, 2015 | 05:55 PM
Everything works, It cranks all the accessories work it just won't fire. one of the sensors on the driver side of the valve cover was of, so I bolted back on, made sure I had fuel. I haven't had a ton of time to work on it. Just looking for things to check.
Thanks
Old Oct 31, 2015 | 05:58 PM
THE REAL DEAL.'s Avatar
fuel cut out switch next to the inside fuse box on the a post.push the rubber on top of the relay looking switch in.
[attachment=86993:gallery_71526_27410_1784668819488 710b722fe4.jpg]
This is of a right hand drive am not sure if they have cut outs in other countries but its compulsory in uk so all cars have them here.
Attached Thumbnails 05 won't start-gallery_71526_27410_1784668819488710b722fe4.jpg
Old Oct 31, 2015 | 06:09 PM
zeroptzero's Avatar
North American S2000's did not get the fuel cut-off circuit.
Old Oct 31, 2015 | 06:17 PM
I have fuel pressure so its definitely not that.
Old Oct 31, 2015 | 07:45 PM
You getting spark at the plugs?
Old Nov 1, 2015 | 02:53 AM
Nope thats the problem.
Old Nov 1, 2015 | 08:27 AM
Ended up being the cam sensor. I just wiped it off put it back in and it purrs like a kitten.
