09 engine problems
Old Feb 23, 2018 | 02:35 PM
alvin moore's Avatar
Default 09 engine problems
i have an 09 with 30.000 mils an just read something about the 08 09 haveing big problems with blow"n engines is this true..can anyone help. many thinks alvin
Old Feb 23, 2018 | 02:46 PM
Hfreak's Avatar
You don't have much to worry about as long as you keep up with maintenance, 08-09 have the same F22 as 06-07. Check out this link to help with keeping your valve lash in check.
https://www.s2ki.com/forums/s2000-un...2A%2A-1060900/
Old Feb 23, 2018 | 02:51 PM
thanks hfreak
Old Feb 23, 2018 | 04:41 PM
starchland's Avatar
Google thrust bearing end play
Old Feb 24, 2018 | 02:53 AM
forgot to say my engine is the f20 c2 as am in the uk. does this make any difference
Old Feb 25, 2018 | 08:12 AM
klemen123's Avatar
I bought a new engine block assy from honda for a 2009 year model.....and after 2000km all my main bearings were destroyed. Cause: rust on main bearings, probably bad material. Honda approved my replacement request and gave me a new engine. I hope this one lasts.
Old Feb 25, 2018 | 08:26 AM
my car has a very slit knocking on startup an only lasts 5min or so till it gets warm. does yours do this
Old Feb 25, 2018 | 08:34 AM
Orjinal's Avatar
European spec 2009 f20c's do have a problem but I'm not sure what the cause of it was. Is your cars engine original?
Old Feb 25, 2018 | 08:39 AM
yes. 100% original
Old Feb 25, 2018 | 08:47 AM
klemen123's Avatar
nope...no knock. Engine is very consistant no clicking knocking from very cold to very hot, other than some little belt noise and injectors...
