1-2nd gear grind
Old Feb 5, 2008 | 10:36 AM
jonnys2k01's Avatar
Default 1-2nd gear grind
so if you ever get that grind... be prepared to buy a new trans like me... bc its about to go... mechanics price on a honda tranny is 3400 spoon tranny 2600(rebuild) used with 90 day warranty 1200
that grind is bad news!!!!
just took it out one day.. and normal driving.. into 2nd... gone...
Old Feb 5, 2008 | 10:41 AM
CalBear07's Avatar
I thought this was very common, even among the new ones?
Old Feb 5, 2008 | 10:44 AM
Amer's Avatar
I don't know, unless you prematurely did the 1-2 grind for a long time, the transmission can take quite a bit of abuse.
Old Feb 5, 2008 | 11:14 AM
s20004lifehomes's Avatar
My tranny did that very minimal, then i drain the fluid and replaced is with gm syncromesche or however u spell it and the problem went away, i hear lots of s2000's with this grind and that usually takes care of it.
Old Feb 5, 2008 | 11:18 AM
J'sS2K's Avatar
I get a "clink" in 2nd in the morning when the tranny is cold, but never a grind.
Jason
Old Feb 5, 2008 | 01:03 PM
jungliano's Avatar
yeah, that's the noise they're talking about. When you warm up your car, put your car in gear several times to lubricate the gears. I can't guarantee it will take the clinking away, but it's less clinking.
Old Feb 5, 2008 | 01:15 PM
u8myrice's Avatar
I have a minor clink when it's cold, but that's it. Before I drive I put my car in all the gears before I roll out.
Old Feb 5, 2008 | 01:22 PM
sharkbite's Avatar
u do not need a trans this happends on all ap1 and ap2s that i have seen. just let it warm up and u have to find a way to shift it better so that ir doesnt do it. we all have this problem.
Old Feb 5, 2008 | 02:58 PM
qsmarcei's Avatar
Jason
Mine does the same thing. If its bad, inform me so I can get them to fix it under warranty, hahahah
Old Feb 5, 2008 | 04:46 PM
iDomN8U's Avatar
Grinding and clink are two different things.
If your grinding is severe, you could adjust the clutch pedal rod, this might help, but I suggest you do this with the utmost caution.
Clunking just needs a slight hesitation between shifts, especially when transmission is cold.
