1 bolt left. Help me with my spring install
Hello all. Im about done with installing my new lowering springs but im stuck on one bolt!.
The order I went in was:
Driver Front
Pass Front
Pass Rear
Driver rear
and im stuck one the Driver rear.
The spring is in. I have the 2 upper bolts near the gas line connected. But im having problems getting the lower bolt to thred properly.
It goes through the 1st piece of metal on the shock assembly...then through the lower arm bushing but it wont hit the other side properly.
Anyone else have a hard time with this part.
It seems to me that this wheel was the hardest to get the bolt out and now...get the bolt in.
The front is lowered and looking good. Now plz help me with the rear...
Driver Front
Pass Front
Pass Rear
Driver rear
Originally Posted by Billman250,Apr 3 2008, 05:31 PM
You'll need to pry DOWN on the lower control arm with a long bar. At least I have on a few dozen s2ks
The other solution is to remount the tire and then use the scissor jack between the tire and the upper fenderwell. This will also force the control arm down easily. DO NOT TRY THIS ON THE FRONT!!!
If you know that the hole is lined up and you still can get it out, I would check your threads. You might need to run a thread chaser throught the hole or a tap. You mentioned it was tuff comming out so make sure the bolt and threads are clean. I suggest when putting it back togather you use a little anti-seize and a proper torque spec, and don't forget to preload you suspension..
Originally Posted by 2poor2mod,Apr 3 2008, 04:30 PM
i just used a decent sized screw driver between the base of the shock and the lower control arm as leverage to line the hole up, it was actuall quite easy. a one man job
I GOT IT LAST NIGHT!
I used a 3' bar and pryed down the LCA. I had my buddy come over and line up everything, then start threading the bolt in.
The car is now sitting sexy on Espelir springs
Thanks
ALSO, i made a time lapse video of the whole install
coming out soon, get ready!
Thanks
