100K Service
I just hit 100k and so far this is what I think needs to be done for a 100K service. Am I missing anything?
Fluid change-
Engine Oil
Tranny
Diff
Brake
Clutch
Serpinetine Belt- Where can I find a cheap replacement $54.xx seems like a lot for a belt
Valve cover gasket
Timing Chain Tensioner
Check all hoses
Clean TB
Maybe-
Oil Jet Bolts?
Map sensor- I have the notorious bog at idle
Fluid change-
Engine Oil
Tranny
Diff
Brake
Clutch
Valve cover gasket
Check all hoses
Clean TB
Maybe-
Oil Jet Bolts?
It is really nothing more than a multiple of the 30k service if you want to look at it simplistically (and would actually fall at 90k). Its only a number. There is no seperate scheduled maintenance called out in the owner's manual. 105 for the valve adjustment is about all I can think of.
Your list is reasonable though. I would......
Omit:
-Belt (inspect for cracks at least)
-Valve Cover Gasket
-Oil Jet Bolts (now, later, never)
-TCT (unless it is noisy)
Add:
+Intake Filter (every 15k)
+Cabin Filter (every 30k)
+Treat and.or Inspect CV boots/rubber seals with Silicone Spray
+Did you service the coolant @ 75k per the manual?
If you've stayed on top of all these things then it really isn't a big deal. DIY FTW and long life of your S.
CONGRATS BTW. I'll be @ 200k soon enough.
-Hockey
Omit:
-Valve Cover Gasket
Add:
-Hockey
