134k compression test
Old Feb 20, 2013 | 08:03 PM
812Throttle's Avatar
Default 134k compression test
Well, I got the dreaded misfire codes. Spark plug tube 3 was full of oil so I replaced all my plugs, tube seals, and valve cover gasket. I still feel a miss at idle. So I ran a compression test. Results are as follows
1 - 80psi
2 - 150psi
3 - 70psi
4 - 140psi
I find it odd that the paired cylinders are reunning within 10% of each other. Maybe a timing issue? The previous owner took horrible care of this car as I'm learning
Old Feb 20, 2013 | 09:21 PM
sahtt's Avatar
1 - 80psi
2 - 150psi
3 - 70psi
4 - 140psi
I find it odd that the paired cylinders are running within 10% of each other. Maybe a timing issue? The previous owner took horrible care of this car as I'm learning
Those don't look good. A healthy cylinder should be >200psi; as a reference my 04 w/26k miles was within 4 psi of factory new spec on all cylinders (240psi).
Have you checked the coolant for contamination to rule out a blown head gasket? Given how bad those numbers are, I'd do a leak down test before speculating.
Old Feb 21, 2013 | 03:58 AM
I'm planning on doing a leak down over the weekend.
Old Feb 21, 2013 | 07:45 AM
rob-2's Avatar
Leak down test it but something is WAY off. Typically you're looking for consistency between each and to be around 180-240.
Old Feb 21, 2013 | 09:07 AM
That's what I'm saying. It doesn't make sense that its THAT low but is still running. I work for toyota but idk anything about these engines
Old Feb 22, 2013 | 07:25 PM
I messed up on my compression test because I didn't open the throttle body. New results:
1- 140
2- 200
3- 200
4- 80
Did a leak down and 1 was coming out of the throttle body. Did a leak down on 4 and it came out of cylinder 1. I'm stumped. No bubbles in the radiator, no air from the dipstick tube or oil cap. I don't have a clue
Old Feb 23, 2013 | 04:46 AM
AF_BLACKBURN's Avatar
The only thing logical answer I could come up with is valve train. I don't think a valve is closing all the way on cylinder 4.
Old Feb 23, 2013 | 02:04 PM
s2cho's Avatar
Do a leak down test. my s ran 190 all 4 cylinders but I'm a mile high here in Colorado and temp affects the numbers. My thoughts are your rings are getting a little toasted... But i could be wrong so leak down and know for sure before putting anymore money into the car.
Old Feb 23, 2013 | 02:59 PM
rob-2's Avatar
I would strongly suggest you check your valve and ensure they're within spec. Maybe they weren't done at 100K. Easy and cheap.
Old Feb 23, 2013 | 04:18 PM
He already did the leak down....
